Old 11-02-2014, 04:56 PM   #1
MittenKitten's Avatar
1965 22' Safari
Hartland , Michigan
Fresh Water Drain for 1965 Safari
Hi -
I've been attempting to winterize the trailer for the first time. I've drained the back grey & black water out from the back drain, ran the sinks, shower and toilet out, but cannot find a low point drain for the fresh water tank.
Any advice?
MittenKitten is offline   Reply With Quote
Old 02-08-2015, 02:10 PM   #2
Whtesocks
2014 31' Classic
Crane , Missouri
My classic has a drain petcock behind the passenger side front wheel. There are 2 low point drain petcocks for your plumbing also in the same area. Be sure and open your facets when draining the plumbing. Some water may find a low point so be sure in the plumbing so be sure you buy some RV safe antifreeze and circulate in your system as a final step. All drains and tanks should have a little antifreeze in them. Also there is a book that came with your unit they will explain the steps.
dmnichols is offline   Reply With Quote
1965, 1965 safari
Replacing Fresh Water Drain Petcock on 99 Safari Clawdan Fresh Water Systems 10 01-14-2010 04:15 PM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
fresh water drain: broke it off. help jparks Fresh Water Systems 12 10-07-2009 06:20 PM
Fresh water drain ? TexasStars Fresh Water Systems 6 10-29-2003 12:09 PM
Fresh water drain Happycampers Fresh Water Systems 0 07-21-2003 04:54 PM
