Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-19-2005, 02:37 PM   #1
jparks
Profile:  2003 25' Safari
dahlonega , Georgia
Unhappy fresh water drain: broke it off. help
barbed end is in line where it enters the fresh water tank. can reach the white plastic barb with pliers. do not want to do futher damage. have replacement valve.
jparks is offline   Reply With Quote
Old 10-19-2005, 06:54 PM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
j parks
try unscrewing it, there is another barb with threads where it enters the tank.
if you get lucky you may remove the whole assembly. then you can repair it and screw it back in.
i'll dig up a thread with pictures in it....
john
you call them ferrets, i call them weasels.
Old 10-19-2005, 06:58 PM   #3
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
here is a photo of the valve system partially disassembled.
you can see the valve, short piece of pipe then the barb with the threads. you can see the one i replaced in the background...
Old 10-19-2005, 10:39 PM   #4
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Funny, all I see is beer.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 10-19-2005, 10:55 PM   #5
maxandgeorgia
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Okay. This $%*&^%!!!freshwater drain is an impossible fixture on an Airstream, at least for Max and me. Can't reach it (between two tires). Can't turn it. Is there a better fix for this, a replacement with long enough turning "handles" to really get a grip? I'm glad this thread raised the question about the freshwater drain handle because I really want to find a way to get rid of this awful little one and replace it with a better "mousetrap." Thanks for suggestions. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 10-20-2005, 06:59 AM   #6
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
On another 34' Excella that we had, the drain valve was behind the tire - not between the tires. So I added a length of hose to the existing valve with an additional valve in a location that I could acess easier.
Dwight is offline   Reply With Quote
Old 10-20-2005, 08:27 AM   #7
jparks
dahlonega , Georgia
thank you-- I will try your suggestions-- if nothing works easily, i will simply put a removeable plug into the broken end? jparks
Old 10-20-2005, 08:39 AM   #8
maxandgeorgia
Ashland , Missouri
Dwight-thanks for a workable solution. A case for me of "cannot see the forest for the trees." This sounds doable and sensible.
maxandgeorgia
WDCU
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 01:03 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 10:02 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 11:28 AM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 11:08 AM
