Old 03-21-2010, 10:29 AM   #1
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Fresh water connection
I wonder how to better make the 90-degree turn to the right, then another 90-degree turn down through the port in the compartment without restricting the flow. I can bring the fresh water hose straight out but then I can't shut the compartment door. Any ideas? -- John
Name:	Airstream pick-up 020.jpg
JBinKC is offline   Reply With Quote
Old 03-21-2010, 10:47 AM   #2
_
hi jb'
yeah that inlet connection is a tight right turn.
try using a 3-5 foot 'leader' hose instead of that 18 inch version.
and a slightly more flexible/pliable hose material.
with a longer connector hose, it can be feed out the hole on the right side for connecting the main hose/filter.
then turn ON the water, check for drips, good seal and so on.
the access hatch will then close without pinching the connector at the inlet.
i fiddled with Ys and elbows and quik connects and other ideas at the inlet without satisfaction.
the 3-5 ft connecting hose has worked out the best.
this remains connected 24/7 and pulls back through the hole to loop around in that compartment.
along with 25 ft of COILed fresh water hose.
cheers
2air'
Old 03-21-2010, 11:41 AM   #3
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I use a Camco Brass 90 Degree Water Hose Elbow. Works good
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
City Water Connection R&SZinser Fresh Water Systems 14 08-20-2012 05:30 PM
connection help for new water tank jlester Fresh Water Systems 2 05-19-2008 11:00 AM
Fresh Water Connection-what is this for? byamcaravanner Fresh Water Systems 8 09-10-2007 06:11 PM
Water connection. Theo Fresh Water Systems 5 01-15-2004 03:09 PM
New City Water Connection j54mark Fresh Water Systems 5 07-01-2002 07:03 AM
