Old 01-17-2013, 07:08 PM   #1
xo1rider's Avatar
2012 27' FB International
Fremont , California
Fresh water being used while using full hookup
I'm trying to figure out where my fresh water is going. Starting out with a full tank then hooking up to city water. Water pump never turned on but then I check the next day or two and find the fresh water down 1/3 to 1/2. No external leak and I verified by filling the water again to make sure it was not just the gauge.
The reason I've been traveling with full or almost full fresh water is the outside air temp. at times has been below freezing and I sometime have to disconnect from city water at night.
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 01-17-2013, 08:05 PM   #2
1988 32' Excella
Robbinsville , New Jersey
The only thing I can think of is that somehow you are getting a venturi effect. The same way some well pumps work where water is pumped down a 1" pipe to a Y to pull water up a 1.5" pipe. (not sure exact pipe sizes just normally 1 is smaller then the other)
If that is the case you could install a valve by the pump.
Old 01-17-2013, 08:52 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
A few of us add a valve between the pump and the water storage tank to isolate the tank during city water connection times.
The usual issue is pump check valve leakage and water tank overflow.
Old 01-17-2013, 09:28 PM   #4
xo1rider's Avatar
Thanks, what type of valve?
Swami Beyondananda
Our travel log
Old 01-17-2013, 10:47 PM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Full port ball valve, quarter turn, must be NSF 61 approved for potable water use. Just like the one in the picture above.
Old 01-18-2013, 09:09 AM   #6
xo1rider's Avatar
Do you keep valve closed on city water then manually open when using pump?
Swami Beyondananda
Our travel log
Old 01-18-2013, 02:07 PM   #7
Splitrock's Avatar
Yes. And I have a second valve that isolates the city water supply for times the pump is used. I have experience with check valve failures on both ends. The valves eliminate dealing with failures during relaxation time.
