Old 08-28-2007, 11:44 AM   #1
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Fresh water air pump conversion
My 62 Ambassador originally had the air pump to pressurize the water tank for use when not connected to city water. Has anyone converted over to a regular pump? If so where does the new pump such as a surflow go in the system?
The PO installed a 110 v airbrush pump, but I would like to have a 12v option for water as I really do not want to purchase a generator at this time.
I appreciate any information on this.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 08-28-2007, 11:46 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I installed an on-demand PAR pump, along with a plastice fresh water tank to replace the leaking steel tank. I replumbed the fresh tank into the pump, then the pump into the system. The pump has a check valve to keep the tank from overflowing.
Old 08-28-2007, 11:55 AM   #3
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
My steel tank is just fine and does not leak. It holds pressure well, and I would like to keep the tank. I am unsure of where I would pipe a new pump in the water system.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 08-28-2007, 12:11 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Make sure you put the pump above your tank or put a shut off valve between the tank and pump. I prefer the first option. Checkout any RV place for a suitable pump. The one I have is a variable speed.
Michelle TAC MT-0
Sarah, Snowball
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
No water to toilet Oak Sinks, Showers & Toilets 13 11-01-2002 06:31 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
