Old 04-24-2018, 06:49 PM   #1
AFTER TAXES's Avatar
1993 25' Excella
Early Bird , Florida
Images: 11
fresh water
fresh tank is empty......what the best thing to put in the tank to
freshen it ?
AFTER TAXES is offline   Reply With Quote
Old 04-24-2018, 07:09 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
My owners manual says to put bleach in a tank full of water and let it sit for I believe 4 hours before draining....I do it each spring.
CRH is offline   Reply With Quote
Old 04-24-2018, 07:22 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
1/4 cup per 15 gallons is a recommended mixture.
Richard
azflycaster is online now   Reply With Quote
Old 04-24-2018, 08:10 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
freshen it ?
There is a section in the owners manual for your trailer that gives instructions for sanitizing the fresh water tank.
If you do not have a manual, you can download one here>
https://www.airstream.com/wp-content...0110i.arc_.pdf
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 04-24-2018, 08:26 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
When we are traveling I wait until the last day and on the way home I add bleach to a partial tank. It will slosh around on the drive that last day and when I get home I run water through the sink faucets and then drain the tank. I try to do this several times a year but don't always. We drink our tank water and have never had any problems with it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-24-2018, 08:46 PM   #6
1993 25' Excella
Images: 11
thx will try that......
Old 04-25-2018, 05:20 AM   #7
Long Island , New York
FYI the new search function in the blue box above works great. Here are the results for "water tank bleach" which will reveal a host of other posts and threads:
https://www.google.com/search?q=wate...=airforums.com
. . . many of them in this sub-forum:
http://www.airforums.com/forums/f443/
. . . including this recent one:
http://www.airforums.com/forums/f443...er-174109.html
Your AS is 25 years old, so you might want to verify/confirm that the water tank is in OK condition. If the the trailer is new to you, and the tank has been empty for a while, there may be other issues with bugs, rodents and so forth. This may not apply to you, but needs to be mentioned IMO, in the interest of good health. If you let us know the history of the unit, you may get better more specific advice.
Good luck!
Peter
FYI and FWIW
Old 04-25-2018, 05:29 AM   #8
r carl's Avatar
Lin , Ne
I just use city water whenever I can because it has chlorine in it.
Old 04-25-2018, 07:08 AM   #9
retired USA/USAF
2001 30' Excella
I forgot to add a comment to my earlier posting. When at a campground I always taste the water before putting into my tank. I've found some pretty nasty tasting water and wouldn't want to put it into my tank even if it's drinking safe. Many don't drink their tank water but for those that do this is a good practice.
See ya'll on the road sometime.
Roger in NJ
TAC - NJ 18
Old 04-25-2018, 09:34 AM   #10
Great suggestion! Do you next filter the water through one of those inline Camco hose filters as part of the taste test? Curious whether you could taste the difference.
Peter
Old 04-25-2018, 07:32 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Peter
I use one (I got a single cartridge whole house residential filter from Lowes) that uses replaceable charcoal filters. I can tell a difference when the filter is new. I camp often in Florida and northward along the east cost where the "normal" drinking water has a rotten egg smell. This filter helps, but does not remove all of the odor.
add edit: I sanitize the filter housing, hoses, and replace the cartridge each time I sanitize the FW tank.
Alan
Old 04-25-2018, 07:57 PM   #12
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Rotten egg odor is hydrogen sulfide. Carbon will help temporarily, but doesn't do a great job by itself.
Add chlorine to your water and the hydrogen sulfide will oxidize to elemental sulfur, which has no odor and is easily filtered out. It's easiest to do this by adding household bleach to your tank and filling it up.
Filter through carbon (immediately after the pump) to remove the chlorine and any disinfection byproducts you may have created. This procedure will also prevent bacteria from growing in your plumbing system. If the carbon filter you choose is a 0.5 micron carbon block, that will also protect you from protozoan diseases.
Water containing hydrogen sulfide is going to be well water, which is likely to also have iron. Adding chlorine to iron bearing water will turn it orange and create sediment in your tanks. Softening your water before adding it to your tank will remove iron, and prevent orange water, sediment, and stained fixtures. It'll also make your soap lather better, and save your water heater from building up lime scale.
So, in short, soften your water before adding to your tank, chlorinate your tank at each fill, and add a carbon block after your pump, and you'll solve most water problems you encounter. I like to purify my drinking water as well, just to be safe.
TheGreatleys is offline   Reply With Quote
Old 01-15-2019, 09:15 PM   #13
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
How long does chlorine last in city water? Or how long can fresh water be held in the fresh water tank?
Thanks!
Old 01-16-2019, 05:59 AM   #14
1974 27' Overlander
Thanks!
Big "it depends." Original concentration, temperature you're storing at, how well the tank is vented, whether they used chlorine or chloramine, whether there was already anything in the tank to neutralize the chlorine.
My personal opinion would be to store chlorinated water in an atmospheric tank up to a few months. If you have any doubts, test for a chlorine residual before using it. A chlorine test kit is cheap and readily available at your local hardware store by the pool supplies. If there is no chlorine left, shock chlorinate the tank, dump, and refill before using.
This is probably overkill in most cases, but it doesn't cost much and it will keep both your water and tank clean.
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 24 05-19-2017 04:45 PM
How long fresh water stays fresh? cellarrat Boondocking 28 02-07-2016 01:39 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
fresh water and black water capacity 64tr0tter Fresh Water Systems 4 10-28-2007 09:24 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
