07-07-2004, 05:11 PM
1980 25' Excella II
Mulvane
, Kansas
Fresh water
Hi
We used RV antifreeze last fall to protect the water lines, etc.
We need help, please!!! We did all the "dewinterizing" the manual suggested, including bleach & vingagar in the fresh water tank. We have ran fresh water through the system so much the neighbors are starting to give us bad looks for the street being wet all the time. We cannot get rid of the terrible odor when we turn on any of the faucets.
What did we do wrong? Thank you for your help...oh wise & knowing "AIRSTREAMERS".
plains70
07-07-2004, 05:14 PM
2004 30' Classic Slideout
Fenton
, Missouri
What kind of odor are you smelling. Is it the same as the anti-freeze in the bottle? It sounds much like something else may be causing the odor. I'm assuming you see no pink tinge to the water. I've used RV antifreeze in the lines and tank for years and never did have a condition like this. I'm assuming the odor is only when you use the fresh water tank and not from city water.
When you used the bleach, what concentration do you use and how long have you left it in the tank?
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-07-2004, 05:42 PM
1980 25' Excella II
Mulvane
, Kansas
The smell is only when we use water from the fresh water tank. It smells a bit like the antifreeze, but it mostly smells kind of sour. The is NO pink tinge to the water.
Flushed the system with fresh water. then did the following...
We started with 2 boxes of soda & 10 gal of water, left overnight,
& flushed system. Then mixed 1/4 cup of bleach per a gallon of fresh water. Poured 3 1/2 gallons of this mix into our 50 gallon tank, filled tank with fresh water & let stand overnight. (Manual says 1 gallon of bleach solution for each 15 gallons of capacity into empty water tank.) Flushed system again, then added 10 qts of vinegar & filled tank. (Manual says 1 qt of vinegar to 5 gallons of water). That is a lot of vinegar too! Stinky!! Set overnight, & flushed completely several more times. Water seems to be ok, not great, for a day or two, but then goes south on us. What have we done wrong?
plains70
07-07-2004, 05:47 PM
2004 25' International CCD
Salem
, Massachusetts
This was our first winterizing and de-win. We did great! No problems and best of all no smell!
We followed the suggestions from a couple of threads here in the forums. They mentioned no vinegar instead suggested baking soda as part of the last step. (check threads for exact quantity, I keep our sheet in the AS).
The steps called for the clorox before the baking soda. I think that might have done it for you, together with all that vinegar.
Maybe if you just repeat the baking soda, a couple of times, you'll do fine.
...next time skip the vinegar...
Someone with more experience may chime in and add some extra info.
Cheers!
KIMILI
07-07-2004, 08:11 PM
Magazine publisher
Ferrisburg
, Vermont
A few questions that may help:
1) How old is Airstream? Are we talking about a vintage unit or a relatively new one? Has any part of the plumbing been replaced?
2) Did you run the bleach/water solutions through ALL the water lines by opening the faucets, before letting it sit overnight?
3) Does your local water normally have an odor (sulphur, etc)?
4) Can you smell the water from a distance when a faucet is opened, or do you have to taste it to notice the "terrible odor"?
RV antifreeze does put a little taste in the water, but it shouldn't make the water smell.
Try a few 500 mg ascorbic acid tablets (Vitamin C). Just toss them down the fill pipe into a tank of water and let them dissolve overnight. That always kills the antifreeze taste for us. But it does sound like your problem is a bit more severe.
07-07-2004, 08:22 PM
The "sour" smell makes me suspicious of algae. Here is the sad part: there is no way to completely drain the fresh water tank. At least not on the later model plastic tanks under the floor. The drain cock is positioned so that maybe a gallon or more will remain after draining.
You might try the old black tank cleaning trick of feeding ice cubes down the filler tube and then taking it for a ride. If it were mine, I'd add about 10 lbs. of ice cubes (boy, is that going to be tedious!) and a gallon or so of water. The ice may "scrub" any algae off the bottom, which repeated filling and draining just might empty out.
Good luck,
Mark
07-07-2004, 10:06 PM
1987 29' Sovereign
Sparta
, Tennessee
Originally Posted by plains70
Hi
Is there any chance it is a sulfur smell coming from the hot water tank. I had trouble this spring after returning from the winter in Texas. The hot water tank was full from March until we started to use it in May. Terrible sulfur smell that had to be flushed out.
07-07-2004, 11:37 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
...2) Did you run the bleach/water solutions through ALL the water lines by opening the faucets, before letting it sit overnight?
This has worked for us. The A/S manual says "4 hours min. of full contact (w/ bleach solution)...on the entire system..."
07-09-2004, 09:51 PM
1980 25' Excella II
Mulvane
, Kansas
Hello. Thanks for all the gret suggestions. We are going to drain everything again this weekend. I'll keep you posted.
plains70
07-09-2004, 10:08 PM
1964 26' Overlander
Norman
, Oklahoma
This is a long shot. Are you filling your fresh water tank with city water or well water? Well water can react with the anode rod in the water heater and cause a bad odor. Another thought might be that you are not flushing all the anitfreeze out of the water heater and that could be causing you part of the problem.
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
07-10-2004, 06:34 AM
2001 34' Limited S/O
Moyock
, North Carolina
I haven't heard of any mention of the everpure filter under the sink. Its a good idea to replace this filter annually. With a little clorox in the water I have found that it will remove most of the odors. Just a personal note, I had a 74 that I did not trust the condition of the potable water tank. I filled it with a 10% soultion of clorox and water, yes I put 5 gallons of clorox in a 40 gallon tank. I pumped the solution through all of my water lines and hot water heater to give me the piece of mind that everything was clean including the gray water tank that filled in the process. It took about 5 fillings and drainings, I use the pump because I wanted to flush the lines as well. It took about a week for all of the clorine odor to go away but it did go away. I was satisfied that the system was clean and replaced the filter under the sink. I have well water and therefore no clorination. Hope this helps.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
07-10-2004, 06:49 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
going back to the original question.
why put antifreeze in the fresh water tank in the first place?
my manual suggests that draining it by the petcock is o.k., the one or two remaining gallons of water can freeze solid and not harm anything.
the rest of the fresh water system can be winterized by blowing out the lines with air, and filling the lines by disconnecting the suction side of the water pump and using a 3 foot section of food grade hose to draw antifreeze directly out of the containers.
i have been doing this since my trailer was new, and has survived wisconsin winters with NO damage!
dewinterizing is easy and requires little time, as there is only about 2 1/2 gallons in the whole system. i have never had a problem with "taste" with my water system.
john
you call them ferrets, i call them weasels.
07-10-2004, 07:36 AM
I disagree
"Here is the sad part: there is no way to completely drain the fresh water tank. At least not on the later model plastic tanks under the floor. The drain cock is positioned so that maybe a gallon or more will remain after draining."
Driving around with the drain open is a good way to get most of the water out
of the freash water tank.
To flush the water heater tank I opened the water heater drain, hooked up to city water and blew it out.
07-10-2004, 08:01 AM
Fresh water!
Hi,
Do you get a strong bleach smell? All the other things already mentioned, could be possible. However, you should only use 1/4 cup of bleach to ten gallons of water. It appears that your dosage for bleach is ten times too much. This might be your problem.
Hope you gets fresh tasting water soon.
Mariner
1987 Avion 34V travel trailer (the other cigar tube).
2002 Dodge CTD 3500 Dually, Auto, 4x4
1986 F250 T/C 6.9 Diesel, LB,S/C,4x4,Auto
07-19-2004, 07:32 AM
Fenton
, Missouri
john
Problem is John, that on some Airstreams the water pump is not easily reached. On my '01 Safari it was going to require cutting the wood trim which surrounded the outward facing panel below the closet. I pulled the screws for the panel only to find it securely held by the wood trim strips which vertically surrounded the closet. Not that it couldn't be done, but a wood worker I am not.
I normally used the antifreeze in the fresh water tank routine and never had a problem in rinsing the tank or winterizing the trailer. The real key is how much water is left in that fresh water tank. Obviously if too much is in there, the poured antifreeze will become diluted. I only used my tank once in the years I owned the Safari so this wasn't much of a problem with me.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-19-2004, 09:54 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
Regards,
Jack
good point jack,
i assumed everyone's trailer was like mine, my wardrobe has a false bottom that has a piano hinge. the whole floor lifts up revealing the pump, water screen, and about 70% of the plumbing in the trailer.
in your case the addition of antifreeze to the tank makes perfect sense!
john
07-19-2004, 10:34 AM
Fenton
, Missouri
good point jack,
john
Yep that's one thing I love about my Classic. Access to the pump. I originally bought a valve that I could insert into the suction side of the pump line. Unfortunately when I tackled the job of installation on the Safari, I ran into the wood issue.
I kept the valve and will put it in this fall. This way I don't have to disconnect for suction from the antifreeze bottle. I'd rather disconnect the line once for the installation than every fall.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-19-2004, 02:04 PM
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon
Regards,
Jack
Jack
Why do you use anti-freeze in your fresh water tank? It's the water lines and faucets (confined spaces) that can't handle water freezing. Though the FWT should be drained before winter, it could handle a small amount of frozen water if one couldn't get to it in time . . . IMHO -Roy
07-19-2004, 02:52 PM
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern
Dave
Wouldn't it be nice if they pulled water from the bottom of the tank insted of the side.
I belive that you could get that last gallon out by putting a hose in the fresh water filler and sucking it out that way.
I don't know why anyone would want to do it except to pull a little sediment off the bottom of the tank.
Peace
Gary
07-19-2004, 02:56 PM
Just a member
1978 28' Argosy 28
Lutz
Parking far out of level side to side with the drain valve open and on the low side should allow for an almost complete drain??
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
