Old 08-30-2017, 03:30 PM   #1
2012 27' FB International
Boulder , Colorado
Fresh tank gauge not reading
2012 27FB International. The fresh gauge is not reading at all. All the lights on the panel are working, ie: when the system powers up and it does the start up routine, all of the lights, including the one on top, light up. I suspect that the connection to the gauge has worked loose. Anyone know where this connection is located, and what type it is(ie: plug, splice, clip, etc). Thanks in advance for any help.
motozen is offline   Reply With Quote
Old 08-30-2017, 03:51 PM   #2
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Try removing the panel from the wall. Unplug and check cords at that point. Mine had slight corrosion at that point. Plugs are standard telephone wire and connectors.
sheriff1 is offline   Reply With Quote
Old 08-30-2017, 04:48 PM   #3
Boulder , Colorado
More info: In trying to track down a slight leak underneath the rig my repair guy dropped the tanks (and while down there replaced the gate valves). I suspect that maybe the connection to the fresh tank sensor was knocked loose or disconnected. I will check the RJ11 behind the panel, but I suspect that's not it.
Old 08-31-2017, 10:40 AM   #4
2004 30' Classic
Hillsborough , New Jersey
fresh tank gauge not reading
I had a similar problem on my 2004 classic. I called the manufacturer and they sent me a new panel and walked me through recalibrating the new one.
If all else fails call the manufacturer. Wolf146
wolf146 is offline   Reply With Quote
Old 08-31-2017, 05:51 PM   #5
Senior Member
sheriff1's Avatar
Sparks , Nevada
The wires generally travel through the belly pans. If trouble started about then I think you are on to it with possibility a damaged wire.
Old 09-16-2017, 01:54 PM   #6
Boulder , Colorado
How do you remove the panel from the wall? No visible screws and I don't want to just start prying without understanding how it's attached.
Old 09-21-2017, 07:37 PM   #7
Boulder , Colorado
Nobody knows?!?
Old 09-21-2017, 07:50 PM   #8
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Is it the See Level panel? Mine has a small indent at the bottom that allows for a very careful prying to pop out of the wall
DaveMc is offline   Reply With Quote
Old 09-22-2017, 07:39 AM   #9
Boulder , Colorado
Thx for the reply. Mine is a Micropulse which has a black housing attached to the wall and a thin metal front panel attached to that with the LED's and rocker switches.
Old 09-22-2017, 01:29 PM   #10
dznf0g's Avatar
Oswego , Illinois
It pops offClick image for larger version
-Rich-
Old 09-23-2017, 06:19 AM   #11
Boulder , Colorado
Aha, thanks!!!
Fresh Water Tank level gauge AraExpress General Repair Forum 3 05-04-2016 02:40 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
Fresh Water Tank Gauge Shads Shack Fresh Water Systems 3 05-04-2014 05:43 AM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 07:38 AM
Fresh water tank reading ESCAPE POD Water Heaters, Filters & Pumps 3 03-30-2008 07:29 PM
