Old 04-12-2010, 10:50 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Fresh tank fill for '64 Globetrotter
So, I've replaced the tank, reconnected it to the trailer, except for the big fill on the outside of the trailer. I have the original fill, which has been redone with a new cap.. the weirdest thing is that I cannot find tubing to go from the ribbed fittings on the filler to the ribbed fittings on the tank. The fittings are 1 1/4 threaded ABS X 1 1/4 ribbed (knurled) slip fittings. Why are the simplest things some how the most difficult to solve? I've looked on line at PEX, but I don't want to buy 100' of it; the local NAPA store tried to sell me a radiator hose. What do others do?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-13-2010, 06:23 AM   #2
1977 31' Excella 500
plano , Texas
Home Depot and get 1 1/4" "spaflex". It is a flexible PVC used in spas. It will handle everything you need and did I mention it will flex? It is schedule 40 so it is quite strong.
-t
tschat is offline   Reply With Quote
Old 04-13-2010, 06:41 AM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
-t
and they will cut it to length
FLYNCLD is offline   Reply With Quote
Old 04-13-2010, 11:07 AM   #4
Globie64's Avatar
Images: 18
Great, thanks. I figured there had to be a really easy fix. I avoid Home Depot like the plague, but solving the last piece of the puzzle is worth the trouble.
Old 04-24-2010, 10:29 PM   #5
Globie64's Avatar
Images: 18
I actually bought some tubing at West Marine because they were handy. I heated up the tubing in a pot of boiling water I carefully carried out from the house, and twisted each end on the the correct fitting. With a little bar soap and all the strength I could muster, the fresh water fill is finally connected to the tank.
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 02:51 PM
'70 Globetrotter Fresh and Black tank Capacities Arizona Al Plumbing - Systems & Fixtures 7 12-26-2009 06:55 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 08:36 PM
fresh water tank for '66 globetrotter nbka1bm Fresh Water Systems 0 12-03-2007 01:59 PM
Fresh water fill Safari Tim Fresh Water Systems 6 05-20-2007 04:50 PM
