Old 12-17-2004, 12:27 AM   #1
RiskIt's Avatar
1972 25' Tradewind
Lake Worth , Florida
Send a message via AIM to RiskIt Send a message via Yahoo to RiskIt
Fresh H2O Tank Size??
Can someone tell me how many gal. the fresh water tank is in my 1972 25' TradeWind is???
RiskIt is offline   Reply With Quote
Old 12-17-2004, 02:47 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Water tank
My 1971 Tradewind supposedly holds about 45 Gal.
Uwe
www.area63productions.com
Old 12-17-2004, 07:13 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I believe my '73 manual says "44 gallons". and it was the same for all models.
black tank size for 23 and 25 foot models is 13 gallons.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-17-2004, 07:20 AM   #4
RiskIt's Avatar
1972 25' Tradewind
Thanks.... 44-45 somewhere in there is fine. Thanks
Old 05-16-2005, 10:47 AM   #5
1974 28' Argosy TT
stinkytwinky's Avatar
1975 28' Argosy 28
Hinsdale , New Hampshire
Send a message via Yahoo to stinkytwinky
!974 Argosy 28'
Be careful as our 1974 28' Argosy has a nose tank and it is only 30 gallons.
You should check with a local Airstream dealership to determine the actual size of your tank.
1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. )
1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
stinkytwinky is offline   Reply With Quote
Old 05-16-2005, 01:05 PM   #6
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Capacity & weight
Multiply (lenght X width X height [in inches] ... divide this total by 231 = gallons
Multiply that total by 8.4 = weight (water) in pounds.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 05-16-2005, 01:23 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I guess you could pour 5 gallon jugs into it until it was full and then you would know for sure.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
