Old 04-15-2015, 10:28 AM   #1
1976 31' Sovereign
Chester , Vermont
Freeze break repair: '74 Soverign
The water supply copper pipes in my '74 are, by design, 5/8 copper. Brilliant !! I need to splice in some pex pipe for now. Having trouble locating 5/8" fittings with Sharkbite push fit couplings, and the 5' of pex pipe I need. Assistance folks, please!
Thomasmg is offline   Reply With Quote
Old 04-15-2015, 10:42 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Where have you looked for the parts?
McMaster-Carr has them.... www.mcmaster.com
perhaps even Grainger.. or a local 'plumbing' store. (especially an 'established' plumbing store)
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-15-2015, 05:43 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Dog gone plumbing parts are sized different ways. Maybe you have measured the OD of your Airstream's copper lines? If you measured 5/8" OD, you are working with 1/2" ID, which is a common size for copper tube and pipe. If you mean the ID is 5/8", then the OD would be 3/4. That's pretty big for a camper.
Here is a reference table for copper tubing:
copper pipe
I suspect your hardware store will have PEX to copper fittings. Sharkbite and other brand "push to connect" fittings may work for you. I've also seen PEX fittings for copper to PEX tubing. These copper fittings require soldering.
You gotta shop by ID size, knowing full well what the OD is when dealing with copper.
I think I've got that right. I often get confused.
David
Old 04-15-2015, 05:52 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A good freeze will "resize" copper pipe quite effectively.
They don't make couplers for these "custom sizes".
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-15-2015, 06:11 PM   #5
1994 34' Excella
Warren , Manitoba
The copper in your '74 is 1/2". Pex to replace as much as possible. Sharkbite fittings are expensive, and in most cases not required. Go to Home Depot and pick up an inexpensive pex tool and start!! The fun begins!!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-15-2015, 08:36 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also... 'tubing' is gauged I.D... Right? The tubing could have expanded, too.. So measure up...
Channing
WBCCI# 30676
Old 04-15-2015, 10:27 PM   #7
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
the pipe swelled from ice,
I tried to make some custom fittings to adapt pex into my '73 to fix a break near the water heater, and I just chased leaks back. until I got mad and replaced it all with pex. replacing the plumbing took a day, and a lot of that was replacing the drain complex near the water tank. then I tried to drain the tank with those drains one time, what a waste. I got rid of the check valve at the city water inlet and just pump the water out of there.
Can of beans is offline   Reply With Quote
Old 04-16-2015, 11:21 AM   #8
1977 31' Sovereign
Lynnwood , Washington
I have a 77 AS. Main water lines are 5/8" copper "tubing;" not the same as 1/2" rigid copper "pipe;" oh so close, but no cigar. 5/8" comes in "tubing" size only. "Pipe" sizes are different.
Proper repair would be 5/8 brass flair nuts together with associated brass fittings and a length of 5/8 copper tubing as needed. You'll need a tubing flair tool for the job.
Plan-B: Use 5/8" compression fittings; if you can find them.
Remember, 5/8 fittings are an odd size. But I have good luck at Ace Hardware when I need them.
However, in addition to the crack in the copper tubing, there's a really good chance that the surrounding tubing has expanded as well, thereby making the above repair virtually impossibe. You'll need to measure the outside diameter (of existing tubing) with good calipers and compare OD with new 5/8 tubing in store.
Plan-C: I purchased two 1/2" plumbing repair sleeves at Lowe's about 12 years ago. They replaced the "inner tube and hose clamp repair" done by the previous owner. My sleeves are well "buried," so I can't measure them. But they're about 3" in pipe length plus another 2" in tightening-screw height. 1) It was an easy repair. 2) I haven't had a leak since. In my book, that's what counts.
IMHO - Use the 1/2" repair sleeves together with a length of 5/8" copper tubing and you should be good to go.
Tom
TomKirk is offline   Reply With Quote
Old 04-16-2015, 12:37 PM   #9
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I've got a Copper/PEX hybrid too from the PO. If you cant find what you need online, find a local Master Plumber or Plumbers supply. They can look at it and tell you what it needs.
I hope it is an easy repair.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 04-16-2015, 02:10 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
pexuniverse.com is great. Replace it all then sell your copper to a recycler. You will get back most if not all of what you spent on the pex stuff. Crimp rings are easy too
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-16-2015, 02:56 PM   #11
1976 31' Sovereign
Chester , Vermont
I found sharkbite fittings, but the freeze expansion damage goes from behind the tub/shower (rear bath) to the kitchen sink. Now I have my work cut out for me. Just trying to get the drain removed from the tub. What a bear. AS threw these things together with glue with no regard for the future !
Old 04-16-2015, 06:54 PM   #12
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
There are 2 different ways to look at piping different wall thicknesses depending on pressure. That said I doubt you'll find 5/8" in a house or trailer. When you buy copper coil or pipe refrigeration is listed by OD & water is listed by ID
garypk is offline   Reply With Quote
Trying to repair freeze damage M. Bondurant Fresh Water Systems 4 10-29-2012 03:51 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
Airstream Soverign 31 SAirstream Soverign 31 eBay Watch Airstreams on eBay 0 09-18-2011 07:20 PM
Airstream Soverign 31 SAirstream Soverign 31 eBay Watch Airstreams on eBay 0 09-08-2011 10:00 AM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
