Old 02-16-2016, 09:32 PM   #1
Springville , Alabama
Flex hose needed on new city water inlet/pressure regulator?
Replacing leaking Shurflo inlet and pressure regulator and directions call for 1 ft of high pressure flex hose between part and rigid plumbing. Original (2005) did not have flex hose, pex was connected directly to the unit. Directions say rigid pipe may make noise and cause unit to crack from vibration. Any thoughts on this?
Also, what type of caulk should I use to seal flange on outside?
driftwood1 is offline   Reply With Quote
Old 02-17-2016, 05:51 AM   #2
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I don't know the answer, however, I'm watching your topic with interest. Hopefully someone with the answer will respond soon.
Ron
Ron
Ron A is offline   Reply With Quote
Old 02-17-2016, 06:05 AM   #3
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Driftwood,
I don't have info on the flexible pipe, but I would would use the following 3M gasket material from McMaster Carr for replacements like this. It is very easy to cut this material to exact size using ordinary scissors. It is very close to the factory gasket material used by Airstream on the water inlet and other exterior parts.
Joe
Name:	ImageUploadedByAirstream Forums1455714297.330977.jpg
jayseejay is offline   Reply With Quote
Old 02-17-2016, 09:03 AM   #4
1998 30' Excella 1000
Livingston , Texas
I replaced mine about 2 years ago. The original installation did not have a flex hose (and it lasted 15 years) and the instructions for the replacement did not mention flex hose. Something new I guess.
Siegmann is offline   Reply With Quote
Old 02-17-2016, 10:08 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Have you considered calling Shurflo and asking Why? i can't think of a reason from a plumbing standpoint.
2004 Excursion 4x4
Old 02-17-2016, 10:24 AM   #6
jackson center , Ohio
I have never heard that one. Airstream has never used flexible hose on shuffling regulator that I am aware of. Normally the pump would cause the lines to vibrate ,it is recommended using flexible hoe on both sides of pump.
Schu is offline   Reply With Quote
Old 02-17-2016, 10:46 AM   #7
Originally Posted by Schu View Post
I have never heard that one. Airstream has never used flexible hose on shurflo regulator that I am aware of. Normally the pump would cause the lines to vibrate ,it is recommended using flexible hose on both sides of pump.
Dang spell check!
Old 02-17-2016, 11:22 AM   #8
Mixter's Avatar
1976 27' Overlander
Ha... got to love auto collect.
Mixter is offline   Reply With Quote
Old 02-17-2016, 11:23 AM   #9
Mixter's Avatar
1976 27' Overlander
errrr.... "correct".
Old 02-17-2016, 12:03 PM   #10
I think I will just put it back as it was... I can barely reach it now from under the sink, and would have to remove the sink and cabinet to put the flex hose on.
It sort of makes sense that connecting a fixed pipe to it might could stress the plastic regulator due to vibration while travelling, but seems like the same logic would apply to other plumbing connections as well....
City Water pressure regulator (location) leak? sinjin General Repair Forum 19 04-18-2018 02:15 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Water coming out city water inlet mutcth Fresh Water Systems 5 05-27-2011 09:23 AM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 09:22 PM
