Hi Ventport: What a great user name for your tread subject! I like it.
I might suggest a rubber grommet fitting for your fill port. I have used them successfully in my holding tanks, and my application was the top surface of the tank, for vent ports and the like.
The rubber grommet fitting is installed after the right size hole is cut with a hole saw into the tank. Then the grommet is worked into the hole. It is a press fit on the OD of the hole. There is a tight fitting rubber flange around the surfaces of the hole. Then a 1 1/2" ID ABS pipe is pressed into the grommet. It is also a press fit, and puts additional pressure on the tank seal.
Take a look...
David
http://www.vintagetrailersupply.com/category-s/439.htm
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
