Old 12-03-2015, 05:49 PM   #1
2014 25' Flying Cloud
Lincoln , California
First Time Fresh Water Tank Fill
I have a 2014 25 ft Flying Cloud, rear bed and for two years we have done full hook up travel. Recently I filled our fresh water tank for the first time (located on the entry side of the trailer). After a short while, I found a slow water leak under the trailer (from the fresh water tank) on the opposite side of the trailer, just about level where the second tire begins. Looking at a rectangle, laying flat, this would be the right upper (or rear) corner of the tank. The two drainage valves are located on the fill side of the trailer. After about one hour or less, the leak stopped and my internal gauge showed my fresh water tank to be full. The next day the area under the trailer was dry. I filled the fresh water tank again (not requiring very much water) and observed the same leak begin again at the same location under the tank. I can feel a hole opening about the size of a 10mm screw where the water leaks from. I am anticipating the leak to stop again and expect my internal gauge to show a full tank tomorrow. I now suspect this is a secondary overflow valve and not a leak. My manual and the Airstream Service Department, over the phone, could not help me. Can anyone confirm my suspicion of a secondary overflow sensor to be true? Jim
dkdeborah is offline   Reply With Quote
Old 12-03-2015, 06:25 PM   #2
2015 30' FB FC Bunk
Ayer , Massachusetts
I'm thinking its a vent disconected from its fitting on the low side and your are filling the fill tube, which drains out.
Two things, I have no clue if there is a vent, and my trailer does not have this leak so it doesn't sound normal.
Ted S. is offline   Reply With Quote
Old 12-03-2015, 06:37 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
My 2012 27FB had a similar problem. Turns out there was a crack high on the tank. Replaced under warranty. No idea of this is your situation or not. Good luck!
Old 12-03-2015, 07:22 PM   #4
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
My 2013 fresh water tank nipple for hose leading to pump cracked. There's no glue or sealant that will adhere to the tank material. The only option is replacement. A new tank is about $200. Labor is the killer. Not a easy job.
kscherzi is offline   Reply With Quote
Old 12-04-2015, 12:15 PM   #5
Tincampers's Avatar
Sneedville , Tennessee
Open the door where the water pump is. You will see a 1.5" plastic hose and a smaller clear hose. The large hose is the fill and the smaller is the vent. If you overfill, the water should come out the little screen by the fill port. Maybe the vent hose came loose.
Tincampers is offline   Reply With Quote
Old 12-13-2015, 12:46 AM   #6
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
Our 2014 27FB Classic also had a crack in the fresh water tank. It would drain down around 1/3 every time I filled it. Replaced under warranty.
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 12-30-2015, 06:51 AM   #7
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Jim,
I just discovered a similar leak on my 2010 28' Flying Cloud yesterday. After checking the forums it looks like a very common problem on Airstreams new and old.
Your best bet is to request a warranty repair from Airstream as the replacement is not an easy task. Please see the excellent post from Alphonse below. It will show you a typical cause of the leak and the extent of repairs.
http://www.airforums.com/forums/f443...ng-114716.html
Old Cobra AH-1G Pilot
WoundedWarriorsFamilySupport.Org
http://www.highfivetour.com/
Snaken49 is offline   Reply With Quote
Noobie - how to fill fresh water tank? Bohemian Fresh Water Systems 26 10-18-2016 02:51 PM
Can water heater fill from fresh water tank? phann Water Heaters, Filters & Pumps 11 05-21-2015 03:07 PM
Unable to Fill Fresh Water Tank forthefew Fresh Water Systems 3 09-06-2010 08:16 PM
Fresh water tank fill jfowler218 Fresh Water Systems 4 04-21-2009 08:36 PM
First time water fill-up.... luckydc 1997 - 2004 Bambi 3 04-05-2004 06:48 PM
