Old 03-12-2016, 08:48 AM   #1
1973 23' Safari
1970 27' Overlander
Boerne , Texas
filling freshwater from shore fitting
I seen people post about setting up their plumbing so they can fill their freshwater tank with the hose connection from shore. I have not seen some of the details as to how to hook into the fresh water tank. I assume one would tie into the regular 1.5 inch fresh water fill hose or put a new hole and fitting into the freshwater tank. Advice and suggestions would be appreciated. Pictures would be great.
Thanks!
Greg
Greg1410 is offline   Reply With Quote
Old 03-12-2016, 09:01 AM   #2
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Tank fill adaptor
How about one of these. Not a hard plumbed connection but it lets you fill the tank.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 03-12-2016, 09:54 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I second Sphere Guy's suggestions. Direct plumbing the fresh tank into the city inlet is just asking for trouble.
Bob Martel
WBCCI# 5766
Old 03-12-2016, 09:58 AM   #4
Nowhere , Somewhere
Not an AS, but my Avion has a valve I can open to fill onboard tank from fresh lookup. Afraid to try it, though. I thought some AS had this also?
avionstream is offline   Reply With Quote
Old 03-12-2016, 10:37 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Be careful not to over pressurize the tank. You can pop it!
Old 03-12-2016, 11:16 AM   #6
Nowhere , Somewhere
Thanks.
Old 03-12-2016, 11:40 AM   #7
Long Island , New York
Ditto to "trouble" comments. If it ain't broke why fix it?
Every trailer should have a new-ish food-grade hose for filling potable fresh water tank, a very simple task.
KISS
Old 03-12-2016, 12:01 PM   #8
HCR
HCR's Avatar
Livingston , Full time traveler
I use one (the screw on extension shown in a previous post) and it's great--especially when filling from a low-flow source, as I frequently encountered in Baja. With a high-flow source, the gadget keeps the hose from jumping out which occurs on mine unless you are standing there holding the hose.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 03-12-2016, 12:05 PM   #9
2014 25' FB Flying Cloud
Mattituck , New York
We use the certified fresh water hose for RV's, an in line water filter and when the pressure is high a pressure reducer. The initial connection to city water is made using a brass "Y" valve. This comes in handy if you wish an additional line but important to relieve the pressure when you disconnect.
After several contraptions to pour bucket water into the fresh water fill we finally settled on a long necked mouth wash bottle it's a more substantial bottle. It fits the opening without holding. all you have to do is cut out an opening to pour the water in.
darsea is offline   Reply With Quote
Old 03-12-2016, 12:27 PM   #10
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
We always use a pressure regulator at the shore water source connection. The adapter that SG posted is great. Shut off valve gives control at point of fill and allows a minimum of water waste in the transition from fill to shut down.
To this point, we have used same hose for hookup and fresh fill. Had seen a "Y" splitter on the hookup connection post filter and it is likely an easy way to fill fresh water.
Good luck on your investigation. Pat
PKI is online now   Reply With Quote
Old 03-12-2016, 12:48 PM   #11
2002 19' Bambi
Lafayette , California
To fill our tank using the freshwater fill on the outside of the trailer, we use the device Sphere Guy shows.
For a variety of reasons, we added, years ago, a manual valve inside of the trailer which lets us fill (without going outside) the freshwater tank when we are connected up to "city" water. Here is one place I have posted about that:
http://www.airforums.com/forums/f37/...ml#post1567462
This is a very old post about our installation and showing the valve:
http://www.airforums.com/forums/f443...tml#post461981
Tim
Tim A. is offline   Reply With Quote
Old 03-12-2016, 12:55 PM   #12
2016 30' Classic
Santa Rosa , California
At Amazon:
http://www.amazon.com/Camco-40003-Wa.../dp/B0006IX850
Walmart also has them online
phann is offline   Reply With Quote
Old 03-12-2016, 05:31 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Thanks!
Greg
And WHERE would you use a "1.5" hose for usual usage??
My hose is 5/8" and others are 1/2" which is usual!
MelGoddard is offline   Reply With Quote
Old 03-12-2016, 07:28 PM   #14
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Our 66 AS was plumbed from the factory with a valve to fill the fresh water tank while connected to shore water source. Simply take the fill cap off while doing so if worried about a burst tank . 50 years of use and the valve and tank work fine .
dannydimitt is offline   Reply With Quote
Fresh water tank filling when connected to shore water redzebra Fresh Water Systems 7 12-20-2013 03:52 PM
1974 Airstream Sovereign filling freshwater tank texasbound Fresh Water Systems 19 04-20-2013 12:14 AM
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 10:05 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 01:43 PM
