Old 08-07-2009, 06:56 PM   #1
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Filling Fresh Water Tank '65 Safari
I have just started to restore a 65 Safari and am working on the plumbing. My question is: When I fill the fresh water tank manually what fills the hot water tank? When I use the city water hook up then the city pressure fills it. If my water pump fills the hot water tank then I would need to do that and then continue to fill the fresh water tank. FW tank holds 30 gals and water heater holds 6 so If I only put the 30 gal. in then I would use 6 gal for the water heater after the pump kicks in. In other words I should not light the water heater until I have turned on the pump?
Help please as I don't know what I'm doing.
Tim
tkasten is offline   Reply With Quote
Old 08-07-2009, 07:00 PM   #2
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
You are correct, if your hot water tank is empty, you will need to fill your main tank, turn on your pump and fill your hot water tank, then top off your main tank. However, unless you have manually drained your hot water tank after your last hook up to city water, then it will normally already be close to full. Also, the thermocouple in your hot water tank should prevent you from overheating an empty tank.
Hope that helps!
FLYNCLD
FLYNCLD is offline   Reply With Quote
2000 25' safari fresh water leak dcsawLoehr 2000 Safari 6 07-29-2012 09:25 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 04:49 AM
Fresh Water tank '68 safari series2a Fresh Water Systems 1 07-05-2011 03:24 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
