Old 07-04-2016, 03:59 PM   #15
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
oh no, so sorry to see this happen to you. It is such a pain to bring AS back for repairs when brand new, or any time for that matter.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-05-2016, 05:40 AM   #16
Gainesville , Florida
There should be a warning in the owner's manual. If not, this is an oversight which should be corrected. There's no pressure regulator when filling tnis tank as there is for the shore water hookup. Be careful!
Old 07-05-2016, 06:37 AM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
When I over-pressurized our tank I put a large diameter hose that we use for gardens in the filler neck that allowed almost no air to escape, and then turned on the city supplied water near full volume.
Lesson learned and should know better. An RV potable water hose is smaller and should cause no problem. High volume and pressure water delivery could still be an issue so one should be careful that the full tank of air (the tank is not really empty) can be pushed out easily.
Doug and Cheryl
Old 07-05-2016, 08:23 AM   #18
Anna Maria , Florida
Originally Posted by guskmg View Post
Just be careful of high pressure city water. It will blow up an unvented container in a heartbeat. I use a screw on filler tube that is vented and you can easily see the potential damage possibilities when it is approaching full and starts to spew out. Be sure a use low flow especially if you are going to do something else while it is filling.
guskmg
City water pressure is usually 50PSI. The hose stuck loosely into the filler tube will blow out with the water as the tank gets over filled to the top. If the system can't handle 50 PSI pressure how in the world does it hold up a tank weighing over 300 LBS when it is full.
franklyfrank is offline   Reply With Quote
Old 07-05-2016, 08:44 AM   #19
Long Island , New York
Originally Posted by kapt59 View Post
I hope Airstream fixes it ASAP.
Welcome to the forum! Sorry you are having a baptism by water . . .
Have you spoke with the dealer?
A total drag that you should have to take care of this!
Good luck,
Peter
OTRA15 is online now   Reply With Quote
Old 07-05-2016, 11:13 AM   #20
jackson center , Ohio
I do not believe it is a structural issue unless the bolts are loose.It appears that it has hit something in the delivery process or unloading off of the transport.
When the tank is full of 40 gallons of water it will bow down.
My thoughts.
Schu is offline   Reply With Quote
Old 07-05-2016, 01:31 PM   #21
dznf0g's Avatar
Oswego , Illinois
My thoughts.
That is my thought as well. There is definitely an impact witness mark there in the center edge.
-Rich-
Old 07-05-2016, 09:25 PM   #22
2016 26' Flying Cloud
niceville , Florida
Well update on the fallen tank.
Airstream fixed it no questions asked. Better than new also.
The old tank, which was only 3 months old is surrounded by styrofoam, and mounted inside a tank pan made of aluminum, riveted edges joints. So it seem impossible that it could move, jump around, or fall.
The now newer fix was use the tank which seemed fine, built a new pan to put it in. Then they custom made 2 heavy duty steel straps, with welded angle iron so it seems pretty strong. Straps are bolted w 3/8 inch hardware.
The tech guy Paul did a great job and even created a screwed on access panel to view connections. To tank in the future.
He also pointed out that it would be pretty hard to improperly fill the tank. The water hose goes onto the opening. Goes down and into the tank through the side of the tank wall.
The vent is in the top of the tank. As water enters the side and fills up the air is pushed up and out the vent hole.
My last guess as to how this may have happened was the dealer may have not completed a full winterization? Left water in tank. Seems more likely that ice could have bent the tank out of shape.? Also when dealer did their prep work they found the hot water tank was cracked, which leads me to wonder if that was forgotten? Speculation I know
Regardless, Airstream service Dept. Did a great job, and applied an out of the box solution. I like that.
kapt59 is offline   Reply With Quote
Old 07-05-2016, 09:29 PM   #23
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Happy for your resolution. Interesting thought about failed winterization. I thought they came winterized from the factory? I could be wrong. Mine has stickers on it saying the unit was winterized - I assumed that's how it was shipped.
Glad you got a good resolution!
Old 07-05-2016, 11:02 PM   #24
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my hose didn't fall out and it was more of the fast volume that ballooned my tank than pressure. The water lines can handle pressure and do, but a tank that size would probably pop with five pounds pressure or even less.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-06-2016, 07:43 AM   #25
1974 25' Tradewind
Calgary , Alberta
A 25 x 50 inch tank (750 square inches on the top and bottom surfaces) would exert an expanding force of 1500 pounds at ONE psi. As the pressure goes up, so does that expanding force, and it really doesn't take much to start bowing out the structure that holds the tank in place.
Alumineer is offline   Reply With Quote
Old 07-06-2016, 09:45 AM   #26
Thank you for this post. It is encouraging to hear the positives re: the service center.
Old 07-08-2016, 06:45 PM   #27
Thanks for the update. Was this your dealer, or another service dept.? Would you mind sharing the name and location so we can all benefit from a good location for service work.
Old 07-08-2016, 10:56 PM   #28
niceville , Florida
Service at JS.
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
A Memorial Day Tribute To Fallen Vets pappy19 Airstream Lifestyle 1 05-22-2014 08:32 PM
Just Fallen in Love...total newbie VtTim Member Introductions 43 02-07-2013 12:21 AM
O, how the mighty (headliners) have fallen! bake315 Upholstery, Blinds, Walls & Interior Finishes 2 07-05-2006 07:38 AM
Honoring Our Fallen Freedom Fighters BobbyW Off Topic Forum 1 05-28-2002 10:08 AM
