Old 09-06-2010, 08:21 PM   #1
BossCamper's Avatar
1973 25' Tradewind
Chatham , Ontario
Extra check valve?
While reading another thread, I had a thought.
I just finished re-plumbing my '73 Tradewind, and in the process, couldn't remember if the pump had a built in check valve on the outlet side. The pump is the old PAR pump that is working just fine after I re-sealed the diaphragms. (had a very slow seep out past one of them when under constant pressure)
Anyway, I went ahead and plumbed a check valve just downstream of the pump.
My question .... will this extra check valve cause the pump any trouble? It certainly doesn't seem to be hurting anything yet.
Loris
Airstream Project Picture Gallery
http://lorisart.org/gallery/thumbnails.php?album=34
BossCamper is offline   Reply With Quote
Is this a check valve? ambassadorT Water Heaters, Filters & Pumps 7 06-09-2009 07:54 PM
Leaking check valve guy99 Fresh Water Systems 2 07-22-2008 03:35 PM
Check valve? Chuck Fresh Water Systems 20 01-31-2006 07:32 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
Check valve (?) Chuck Fresh Water Systems 9 11-03-2002 09:19 PM
