Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 10-06-2009, 08:48 PM   #1
Profile:  1971 23' Safari
Marietta , Georgia
external water connection?
This white plastic connection labeled "water" is on the outside of our '71 Safari on the street side of the trailer approximately behind the sink. Not sure what it is. Any ideas? I also need to replace it as the tab is broken.
David
AIR # 19018
'71 Safari 23' (Moe)
'08 4Runner V8 4X4
Yamaha EF30iSEB
pickerdd is online now   Reply With Quote
Old 10-06-2009, 09:08 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
That's a water fill port for your onboard fresh water tank. Most any RV dealer can sell you a new one.
(No Longer at Inland RV)
Old 10-06-2009, 09:22 PM   #3
Marietta , Georgia
Thanks Terry. Would my trailer have multiple fill ports? There's a threaded inlet under the rear curb side near the rear bumper that the PO said was the fresh water inlet ot connect to a hose for city water.
Thanks for your help!
David
AIR # 19018
'08 4Runner V8 4X4
Yamaha EF30iSEB
Old 10-06-2009, 09:31 PM   #4
w7ts's Avatar
Profile:  2010 31' Classic
Longmont , Colorado
Hi David, That would be correct. The large one in the picture pulls out and you fill the fresh water tank from there with a hose. If you connect a hose to the other one, that will supply the water to the plumbing system provided the pump is off. If the pump is also on you may get a mixture from both sources.
Regards,
Ken
w7ts is offline   Reply With Quote
Old 10-06-2009, 09:44 PM   #5
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
The water fill you need - as Terry said - most RV dealers carry these:
RV Surplus
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 10-07-2009, 02:08 PM   #6
Marietta , Georgia
Thanks folks! I appreciate the help!
David
AIR # 19018
'08 4Runner V8 4X4
Yamaha EF30iSEB
external water heater idea harker70 Water Heaters, Filters & Pumps 4 08-01-2009 05:59 PM
Black water holding tank changes for using trailer as stationary home/external septic bol-gordon All Argosy Trailers 3 05-20-2009 08:34 AM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
External Water Shut-off on FB units wheel interested 2007 Classic (all lengths) 8 09-10-2006 12:12 AM
External Antenae Connection Raptorrider2001 1999 Safari 9 01-12-2003 11:02 PM
