Old 07-22-2014, 11:33 AM   #1
1983 31' Excella
Quincy , Florida
External freshwater tank...am I nuts?
Hey guys,
I hope this isn't too laughable. We are some newbies brainstorming about systems for our 83 Excella (just frame/floor/shell, everything else will be built form scratch).
We were wondering if it would be possible/viable to keep our freshwater tank externally...for a couple of reasons. One, we plan to live in the trailer full time, and when we're parked, we want to put in a rainwater collection/filtration system. Seems easier with external barrels/tanks. Two, we'd like the option to not have to move our entire trailer in order to fill the freshwater tank, if there wasn't a good water source where we end up staying. We could drive it, fill it cheaply, then come back to the trailer and hook back in. Ideally, we'd also be able to plug into city water when/if available.
Ok, can y'all imagine this working out at all? Any ideas, or big cons? Thanks for humoring me/any input you might have.
BearBones is offline   Reply With Quote
Old 07-22-2014, 12:08 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would not recommend removing the in house FW tank. An Auxiliary tank in the TV to replenish the onboard tank is what I do. I have the Aux tank rigged up with a pump and simply plug it in to the trailer connector on the TV for power to run the pump.
Old 07-22-2014, 12:51 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Assuming you don't have a freshwater tank to remove, and are looking to start from scratch, you still need an onboard freshwater tank permanently connected to your demand water pump. Otherwise getting the pump primed and keeping it primed will be a perennial problem.
If your onboard supply isn't adequately large, you can refill the onboard tank from blue Jerry-cans without much trouble. And you can use your rainwater filtration system to fill the blue Jerry cans in the first place.
You'd still be able to hook into city water when available. Most RVs have a separate municipal water hookup that bypasses the water pump (and check valves to keep one system from back-feeding into the other).
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-22-2014, 01:34 PM   #4
Gainesville , Florida
You can buy water tanks that fit in the bed of a pickup. Fill these up and you might be able to gravity feed this into your AS on board tank. If not then an inexpensive pump can be used to fill the AS tank. You would need a lot of rain to fill buckets from the runoff from the AS roof. Jim
Old 07-22-2014, 02:07 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I also think it's best to keep a permanant FW tank in the trailer.
Another issue; if there is a full water tank in the truck bed, in addition to the trailer's tongue load, it might exceed the truck's payload when towing. It's better to keep the weight of the water on the trailer's axles.
Alan
A W Warn is online now   Reply With Quote
Old 07-22-2014, 02:11 PM   #6
After the trailer us set up and you have used most of your water, then you go fill the truck bed tanks. Jim
Old 07-22-2014, 02:23 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Second what others have said about keeping internal fresh water tank. Additionally, you not only need to consider what happens as you get low on FRESH water, but what's happening to your gray and black water tanks. If you're not in a site with a sewer to dump into you're going to have to move gray/black water TO a dump site. There are external "blue boy" tanks... or you move your trailer! If you move the trailer, it can be an opportunity to refill the white tank too.
Paula
Oh, and the gray and/or black tank always fill up one day before you're planning to leave, Murphy's Law. Gray fills first - prolong your stay by manually dumping dishwater/shower water down the toilet, but watch out for stray forks in the dish pan!
Old 07-22-2014, 02:52 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
One advantage to the fresh water tank is to lower the CG of the trailer. I have seen videos of an AS running a chicane and the difference is remarkable how much "roll" you get with an empty fresh water tank.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-23-2014, 09:53 AM   #9
1983 31' Excella
Quincy , Florida
This has been really helpful folks- looks like refillable cans kept in the truck are the answer. In terms of weight, the trailer will not be connected to the truck most of the time, so the additional weight in the truck bed shouldn't be too much of a problem. I was just hoping to save some space in the trailer. Re: rainwater- we were going to build a shed-like structure to collect rainwater, I couldn't even begin to imagine getting anything off the smooth, rounded AS surface!
Old 07-23-2014, 12:33 PM   #10
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Where is the fresh water tank in your trailer? Is is not under the floor like they were in the 70's?
Old 07-23-2014, 12:41 PM   #11
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The space you'd be saving is under the floor...not really useful for much other than water tanks anyway.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-23-2014, 05:23 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In my '74 Argosy. The grey water tank is the only tank under the floor.
Old 07-23-2014, 05:38 PM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
And, to be useful, the freshwater tank must be protected from freezing.
Some freshwater tanks are installed in the living space for this reason.
In other cases, the tanks are in a enclosed belly pan that has furnace heat directed into the space.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
Overflow hose in freshwater tank is loose. TBKP's Overlander Fresh Water Systems 1 08-03-2003 08:46 PM
