Old 08-31-2011, 01:44 PM   #1
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
External Fresh Water filler spout
I'd like to replace the external fresh water filler spout in our '71 Safari . The original broke a couple of years ago and I replaced it with a cheap white plastic thing. It leaks and is junk. Does anyone have recommendations on something that's high quality and won't leak? I'd like to have a metal (preferably stainless steel) filler spout, but I'm open to suggestions.
Thanks for your help!
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 08-31-2011, 02:09 PM   #2
1966 30' Sovereign
Mount clemens , Michigan
I bought this one but have not installed it yet. I like that it does not need a key, you press it and it pops up enough so you can unscrew it by hand.
Pop-Out Deck Fill for Water, Stainless, No Key Needed | eBay
Brianv512 is offline   Reply With Quote
Old 08-31-2011, 02:44 PM   #3
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks, that's an excellent suggestion. I'll check it out.
- David
Old 08-31-2011, 02:56 PM   #4
dznf0g's Avatar
Oswego , Illinois
On the same subject, but different application. Has anyone found a stainless replacement for the newer big square water fill doors? Also, how about the outside AC power outlet cover? I know where to get the Marinco AC inlet.
If I can find those two things, I will have no more plastic on the exterior. Already got the stove vent, water heater and furnace covers in stainless.
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 05:49 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 08:02 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 11:10 AM
