Old 02-10-2003, 01:49 PM   #1
Swingking's Avatar
Exterior Drain Question
There is a outside water drain installed on the front left corner of my 1969 Overlander. It is located underneath the water pump.
What is it for?
why does water drain out of it when I turn on my water pump?
I am trying to diagnose my water system (this is my first RV). I see water going through the water filter...
(I think the clear bulb thingy is a water filter).
...but water never makes it to the kitchen sink.
please note: water makes it to the kitchen sink when I have city water connected.
Thanks!
Mark
Swingking is offline   Reply With Quote
Old 02-10-2003, 02:11 PM   #2
New Borockton , Alabama
Images: 21
That should be the drain for your water tank. Next to the water pump should be a valve with a hose going down through the belly. Close it, and the water will not drain when you turn on the water pump.
Randy
Old 02-10-2003, 02:13 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Low point drain
Sounds like a low-point drain for winterizing the trailer. Close the valce on it and you should have pressure to the sink.
John W. Irwin
WBCCI #9632
Old 02-12-2003, 06:31 AM   #4
Swingking's Avatar
thanks for the advice!
it is indeed a drain with a valve on either side. one for the water tank and the one for the city water (I think)
thanks again!!
Mark
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
