Old 11-05-2007, 12:42 PM   #1
Mrs_RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Everpure Cartridge and Winterizing
Well, we winterized the Airstream last weekend and put it into storage yesterday. It is in a locked building which technically we can't get into until spring. I just realized that I forgot to remove the Everpure water filter cartridge. We did run the RV antifreeze through it since we replace it every spring, anyway. Last year I removed the cartridge and brought it home, but this year I forgot. Do you think it will cause a problem or are we OK? I could probably sweet talk the caretakers into letting me in the building.
BTW: When we ran the "pink stuff" through it the water kept coming out clear so we weren't sure but decided that the filter was probably removing the color. Just to be safe, Hubby dipped his finger into the running water and touched it to his tongue. He made this face so we know it made it through.
Mrs_RedSHED
Mrs_RedSHED is offline   Reply With Quote
Old 11-05-2007, 02:03 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Mrs_R -- I would suspect your cartridge is adequately winterized. It may be toast and need to be replaced in the spring -- or at least I've always heard that the carbon filters are done when pink stuff is run through.
5 meter Langford Nahanni
Old 11-05-2007, 02:25 PM   #3
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
I did this last year and replaced it with a new filter from Ebay in the spring. Supposedly there is a cap that you can use to bypass and run the antifreeze straight through but I never received one with my AS.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 11-05-2007, 02:29 PM   #4
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Thanks for the tip on filters, I found the one in my 1975 Airstream, it is a ADC quick connect unit, but wow 50 bucks!
Jim in Pima is offline   Reply With Quote
Old 11-05-2007, 02:44 PM   #5
1994 30' Excella
Mississauga , Ontario
Check out Camping world.
They are cheaper there and they usually have a smaller version of the canister for sale in two packs.
I think the small ones would be fine if you only camp on weekends etc.
With the full size filters I wrap it in a freezer bag and reinstall the next season.
Since my water is municipal it does me just fine for two seasons.
Al
Old 11-05-2007, 02:47 PM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
We remove ours every year and I blow the lines. I hate having all that junk in my 'fresh' water system. If you did run the anti-freeze through your system you will be fine, just remember to replace the filter after your first fresh water pass.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-05-2007, 03:02 PM   #7
2014 16' Sport
Columbus , Indiana
Thanks for the advice and reassurance.
As a matter of fact we do replace it before the first trip every spring. When we bought the airstream last year I found a sort of manual for the everpure system online and it mentioned the cap used for winterizing. We didn't get one with our A/S either. I found a place that sells them but we figured we could just run the antifreeze through the old cartridge while winterizing as long as we replaced the cartridge in the de-winterizing process in the spring. Last year I did remove the cartridge post winterizing but pre- storage so I would have it as a reference when ordering it's replacement.
Mrs_RedSHED
Old 11-05-2007, 03:19 PM   #8
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
For those with the newer Safari and the Moen Choiceflo 9000/9001 filter system the best price I could locate on new filters was about $24 each at Faucet Depot: Moen Faucets, Delta Faucets, Grohe Faucets, Insinkerator Disposals. Shipping was only $6.99 for two. They probably have filters to fit other units too.
SilverCottage is offline   Reply With Quote
Old 11-05-2007, 03:30 PM   #9
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I thought you could get the filters at Lowe's. The one in the photo doesn't look like the one for my faucet. The one for my Moen is long and thin. These look shorter and thicker in the photo.
Family of Disney Fanatics
WBCCI# 4821
Old 11-05-2007, 04:25 PM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you did in fact displace the water in the filter by drawing anti freeze through the filtered dispencer the canister should be fine from a freezeing standpoint.
2004 Excursion 4x4
NIBCO Shower Valve Replacement Cartridge Condoluminum Plumbing - Systems & Fixtures 9 07-29-2011 08:23 PM
De-winterizing frozen chosen Winterizing, Storage, Carports & Covers 9 12-06-2007 07:14 PM
Replacement cartridge valve stem for my Moen shower, Help???? jerrodwong Plumbing - Systems & Fixtures 4 09-10-2006 08:42 PM
Everpure Water Filter? jrpappa Water Heaters, Filters & Pumps 4 12-29-2003 12:14 PM
Everpure EN-1 Water Purifier TheBigRedTruck Water Heaters, Filters & Pumps 2 06-06-2002 07:36 AM
