Old 07-15-2010, 07:16 PM   #1
r carl's Avatar
Lin , Ne
Empty or Full
I have been going out camping every 2 or 3 weeks, should i keep my fresh water tank empty or full between trips when my trailer is sitting idle? It has a poly tank.
Old 07-15-2010, 09:04 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We do not drain our fresh water tank between trips, as we go out frequently as well. I'm of the opinion that it's best to prevent the system from drying out, particularly in our dry, hot climate ... We do treat the fresh water with a very mild bleach solution to keep it sanitary...
TB & Greg and Abbey Schnauzer
#3954
Old 07-15-2010, 09:43 PM   #3
r carl's Avatar
Lin , Ne
What i have been doing is coming back from camping with an empty tank and filling it from the house figuring the city water has some clorine in it. When i go camping again i just drain it and fill up with water at the campground. I would rather tow with an empty tank.
Old 07-15-2010, 11:32 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Clorox (sodium hypochlorite) is not effective for long—hours, my microbiologist wife says—as a disinfectant. The chlorine in city water may be different and last longer, especially if not exposed to light. We disinfect twice a season with a Clorox solution—use it fast after measuring out the right amount. Let it stand for a while (formula is in owner's manual), and then flush several times with water.
I don't like leaving water to stand in the tank for very long as any bacteria present may grow. Disinfecting is a pain, but so is getting ill.
So, to answer your question, I'd, at the least, flush the tank a few times before leaving on a trip. We also bring some gallons of drinking water with us. When I make tea, I have boiled the water and it has gone through 2 of our filters. Campground water should be suspected because we don't know where it comes from and do know people who got giardia from campground water. A 5 micron filter can eliminate giardia, but not every other nasty thing.
Maybe we are extra cautious, but I don't argue (much) with a microbiologist.
Gene
Old 07-16-2010, 05:39 AM   #5
r carl's Avatar
Lin , Ne
My brother is a supervisor for cleaning crews at a meat packing plant and one time he told me when you use clorox in a bucket of water for disinfecting its only effective for about 15 min. They use a clorox that is twice as strong.
Old 07-16-2010, 07:07 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If you don't want to travel with a full tank, you might think about having at least some water in your fresh water tank while traveling ... just in case something goes amiss during your drive and you have to stop along the way on the side of the road, or to use the facilities... It's happened to us before! Sure glad we had water!
Happy trails!
#3954
Old 07-18-2010, 09:52 AM   #7
r carl's Avatar
Lin , Ne
Happy trails!
Yes you should travel with some water in the tank. I just dont feel good about traveling with a full tank because in my case 65 gal weighs #540. I suppose i should just treat the tank water while it sits idle. I originally was wondering if there would be less growing in the tank it it was full or empty with city tap water.
Old 07-18-2010, 10:53 PM   #8
Master of Universe
Gene's Avatar
I and others haven't found that a full water tank makes any or much difference in gas mileage. This is not very scientific, more an impression. Some like to keep the potable water tank full because they say it improves trailer stability, probably by lowering the center of gravity.
Gene
Old 07-19-2010, 06:13 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Water
Your fresh tank is normally the farthest forward - full it adds to your tongue weight - and stability of the trailer. I traveled with mine empty when I first started - a 22' which didn't make that much difference. With the 25' it's still tows well either way, but having enough tongue weight especially with a big tow vehicle seems to help handling.
Early on, after a rally with particularly rich and plentiful food I developed an urgent lower G.I. condition about 50 miles out on the road..... I had to use a "box-o-wine" to flush the toilet. Won't repeat THAT mistake. I've also gotten so tired I've had to stop and rest - never drive with the water heater on - and a short cold shower can work wonders.
Paula
Which AS for almost empty nesters? tksbaskets Our Community 54 07-16-2010 08:49 AM
How to empty cylinders hagnik LP Gas, Piping, Tanks & Regulators 15 10-13-2009 10:39 AM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 09:31 AM
my gas tanks are empty! tfetterer LP Gas, Piping, Tanks & Regulators 32 11-05-2007 10:16 PM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
