Old 03-03-2003, 09:11 AM   #1
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
E-PEX tubing
When I modified the dinette in my trailer into a couch, I had to cut several E-PEX tubes in order to route the wires and relocate the water pump. I bought some E-PEX tubing and attempted to use common tube clamps to reconnect the system. I had leaks at each connection that would not stop short of stripping out the clamps. Apparently, the E-PEX is just too rigid to compress in this manner.
I found this just a day before leaving for a week-long trip. My only recourse was to buy the E-PEX crimping tool ($$$) and copper rings (the wrench block was not available).
The first thing I found was that the crimping tool takes a lot of space to operate. I was just barely able to crimp the connections without dissasembling the couch.
Anyone using PEX to replumb a trailer should try to pre-assemble sections of plumbing in open space as much as possible.
John W. Irwin
WBCCI #9632
Old 03-03-2003, 10:01 AM   #2
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
thanks
thanks for the info, I just spent the weekend tearing out the bath in the overlander after finding rot on corners under the tub and toilet. Since I had to remove all of the copper tubing I was considering going back with the E-Pex, but I think I'll just go back with the copper, it's easy to work with and I've got tons of fittings and pipe laying around.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 03-03-2003, 10:57 AM   #3
There are a couple of other options. Flair-it brand fittings appear to be very secure, and, in theory, tighten down by hand. I always give them another turn with pliers. There is also the Qest plastic fittings. These are much larger and bulkier, but are much easier to work with, and can be tightened with a wrench. Finally, there is a crimping tool for the brass Qest fittings that looks and works like a muffler clamp - you place each part around the tube and tighten it down with a wrench or socket. It is designed to work in tight places.
But, in general it is much easier to assemble it first berfore installation when you can.
Mark
Old 03-03-2003, 12:03 PM   #4
Pahaska's Avatar
Hays County , Texas
Wrench block
Unfortunately, the wrench block wasn't available; since I was leaving in about 18 hours, I had no time to consider options. I was connecting to existing Tees, so other types of fittings weren't practical.
John W. Irwin
WBCCI #9632
Water Leaks? - New Repair Product COArgosy78 Plumbing - Systems & Fixtures 10 05-27-2008 01:22 AM
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Air Conditioner-Alternative boltos Our Community 16 06-30-2003 02:03 PM
