Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 11-17-2017, 08:17 AM   #1
Dumping wastewater on Argosy 26
Ok. Acquired a 1973 Argosy 26 coupla weeks ago. Even had the original owners manual. I need to know about dumping the tank ( tanks). There is one outlet i can see and one valve i know of, is that all there is?
Jerry lowe is offline   Reply With Quote
Old 11-17-2017, 08:30 AM   #2
Lily&Me's Avatar
Normal , Illinois
Your owners manual should give you that specific information...
Maggie
Lily&Me is online now   Reply With Quote
Old 11-17-2017, 09:44 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In '73, these trailers were built without a grey water tank, and an acceptable practice at the time was to allow grey water to just run out on the ground.
So, unless a previous owner has added a grey tank and changed the dump valve, what you would see if you dropped the belly skin surrounding the dump valve would be the valve assembly coming down from the black tank with a single gate valve keeping the black water in place, and an inlet connecting the grey water system (not tank) downstream of the black valve. So in this configuration, you put water down your sink drain, and it runs right out of the bottom of the dump valve assembly, and the only thing that dumps when you actuate the dump valve is the black tank.
good luck!
Sewage and WasteWater Labels Switched? Adventure.AS Waste Systems, Tanks & Totes 39 04-26-2017 10:37 PM
Can I/Should I Remove Screen on Water Inflow to Wastewater Tanks? Kellycanoe Waste Systems, Tanks & Totes 9 07-21-2015 07:28 PM
Adding wastewater-tank to Bambi 422 Felix Salten Waste Systems, Tanks & Totes 0 09-14-2013 02:53 PM
Help: Size of wastewater tank?!!! fallon Waste Systems, Tanks & Totes 5 03-08-2011 02:08 PM
Wastewater System rrg Waste Systems, Tanks & Totes 0 01-02-2010 07:39 PM
