Old 06-11-2010, 04:51 AM   #1
1978 28' Ambassador
Savannah , Georgia
Drip, drip, drip
Filled fresh water tank. Turned on pump. Pressures up. Pump shuts off. A minute later pump comes on for five seconds and then shuts off. Noticed a constant drip coming out of city water hook-up connection. The check valve is welded to water hook-up. One suggestion is to cap city water connection. My question is where or what could cause the water to escape through this connection? Is this normal? I do not plan to use water tank, but to stay connected to city water at campground. If there is a leak some where, how do I find it? The supply to the toilet is turned off. Thanks for any and all help. Jack
Skamper1 is offline   Reply With Quote
Old 06-11-2010, 05:21 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jack,
I would say if you cap the city water connection and your pump stops cycling, you've found the culprit. It is most likely the check valve at the city water connection. If after capping the city water the pump still cycles you need to keep looking for another leak.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 06-11-2010, 05:25 AM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Screw one of those little valves for hoses with the on /off lever to your city water inlet. As said above, most likely the check valve.
If this works you can make permanent repairs at your leisure
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-12-2010, 04:45 AM   #4
1978 28' Ambassador
Savannah , Georgia
Added an external on/off valve. It worked! The pump only comes on when I open a faucet and then the pump shuts off. I did open the "new" on/off valve at the city water connection and a stream of water shot about twenty feet under pressure for about a second. Did not realize the pump keeps the entire system under pressure. Looks like I need to replace the check valve. Hope I don't do more harm than good using a welding torch. Thanks for the advice. Jack
Old 06-12-2010, 05:46 AM   #5
1977 31' Excella 500
plano , Texas
Skamper,
That fix will work until winter. That valve is probably external to the temperature controlled part of the trailer. I would install a valve inside the trailer or replace the check valve.
-t
tschat is offline   Reply With Quote
Old 06-12-2010, 08:53 AM   #6
DEITZ645's Avatar
Skamper,
What were you doing with a welding torch???
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 06-12-2010, 01:36 PM   #7
1978 28' Ambassador
Savannah , Georgia
Haven't fired up a torch yet. Old check valve is welded to city water hook-up. Will need to remove old to install a new one. Putting it on my long list of things to do. Last time I used a torch I nearly burned down my home! Jack
Old 06-12-2010, 02:50 PM   #8
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Huh?
Soldering copper pipes with a welding torch? Not within my skill levels. If this causes you concern go another route. Cut out a small section of pipe & install a check valve with compression fittings. This will make changing it out in the future much easier. You can leave the old valve in the loop as long as it's not leaking.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 06-12-2010, 06:33 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
No need to solder copper when there are SharkBite fittings.
Very durable and super easy to install, even in very tight applications. They WILL solve your connection problems!
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
Drip, Drip and Crack jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-06-2006 08:17 AM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
