Old 05-04-2009, 09:54 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Drilled a hole in water tank, HELP
I accidentally drilled a 1/4" hole in the top of my fresh water tank.
I was drilling a 2-1/2" hole in the floor with a hole saw and mis-calculated where the fresh water tank is, luckily only the 1/4" pilot drill went through the tank.
How can I repair this?
Two things I can think of to fix this are, polypropylene welding rod and hot glue gun or tap it 5/16-18 and put a stainless steel bolt in it.
Your thoughts on ths would be appreciated.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 05-04-2009, 09:58 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Is it the original, or a replacement tank? You may be able to go to a plastic company with it, and have a threaded hole spin welded in place, then thread a plug into the hole.
Old 05-04-2009, 10:03 PM   #3
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Thumbs up
good idea
osolow is offline   Reply With Quote
Old 05-08-2009, 05:58 AM   #4
1992 34' Excella
1972 31' Sovereign
Spartanburg , South Carolina
It may be you can use the same technique that is used to mount the level sensors in the tanks. In my '92 it appears to be a 1/4 inch hole drilled into the tank with a short metal probe held in place only from the outside by either welding or gluing. Sorry that I do not know how those probes are attached.
Julian H is offline   Reply With Quote
Old 05-08-2009, 06:15 AM   #5
ctdair's Avatar
Expandable rubber plug , find the smallest expandable freeze plug at the auto store or boaters use rubber plugs for sealing drains. You may have to up the size of the accidental hole for this method.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 05-08-2009, 06:27 AM   #6
silverhawk's Avatar
1964 22' Safari
Elyria , Ohio
Images: 20
Send a message via Yahoo to silverhawk
Someone had to say it, so I will. Duct Tape.
silverhawk is offline   Reply With Quote
Old 05-08-2009, 06:48 AM   #7
lynn's Avatar
8 Pack of Well Nuts
$14.95 $9.95
Model: Well Nut 8/pk
8 Pack Of Well Nuts For Signicade A-Frame
[FONT="arial,]Rubber grommet with metal threads that expand when the screw is tightened, something like a special Molly Screw, but for thin ridged materials like the Signicade A-Frame Sign.[/FONT]
These come in different sizes and can be used to fill holes in plastic tanks
lynn is offline   Reply With Quote
Old 05-08-2009, 07:56 AM   #8
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
I would say plastic weld sold at Walmart mix it and put some in a Katcup bottle and fill the hole .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 05-08-2009, 08:19 AM   #9
1977 31' Sovereign
Images: 33
Did the center piece fall in tank that would be What I worry about ?
Anyone know what kind of plastic the fresh water tank is made of?
If it is ABS plastic I would get a piece of ABS plastic that is over size of the hole like a inch .
1) Clean area with PVC cleaner (PVC pipe cleaner) preps plastic and work area for bonding.DONT use to much it will soften plastic if excess is left on
2) Use PVC cement (for abs,pvc,) apply to ABS piece and to area your covering .Then apply piece to hole.
3) Apply cement to edges like five or six times letting it dry between layers.
I used this method to fill in the hole I had in my tub from having to cut out drain which was rusted solid.
K/N Cool intake air
Duel power exhaust
Old 05-08-2009, 08:24 AM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
Since it is o the top of the tank and will never see any pressure and you can get to it through the 2 1/2 in hole i would just use a Boiler Plug. They are self tapping screws with a rubber washer.
2004 Excursion 4x4
Old 05-08-2009, 08:25 AM   #11
Images: 59
Go to your local home supply store and buy a coil of 1/4" polyethylene tubing. Insert the tubing through the hole and route the tubing up behind the gaucho.
Fill the water tank with beer.
Insert the other end of the tubing into your mouth, recline on the gaucho. Enjoy.
markdoane is online now   Reply With Quote
Old 05-08-2009, 12:47 PM   #12
Mexray's Avatar
1978 28' Ambassador
Morada , California
Quick and neat....SS screw, rubber washer, some silicone sealant...it will probably outlast the trailer!
Ray & Pat; Morada, CA
Old 05-08-2009, 03:46 PM   #13
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
Don't feel bad. When I was in one of those "don't need a man,"moods when I was single, I was hanging a hook from my basement ceiling and accidentally hit the main sewer pipe. My "rent a husband" couldn't stop laughing and besides not being able to use the water for 48 hours it cost me $70.00 to repair the pipe and the dry wall.
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 05-09-2009, 06:27 AM   #14
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
JB Weld is another option. On my old SOB I fixed cracks as long as 6-8" with fiberglass and JB Weld. that was 5 years ago, no leaks. With a hole that small you might get away with just JB Weld. For added security, put a small fiberglass patch over the hole, and then JB Weld all over that. The JB Weld will outlast the black tank.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-09-2009, 08:11 AM   #15
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
I have seen a bunch of great ideas here. I would go along with the two part epoxies made for patching gas tanks, etc. It cures fast and is impervious to liquids. Walmart carries it.
94Tri is offline   Reply With Quote
Old 05-17-2009, 09:18 PM   #16
1977 31' Sovereign
Images: 33
I was going to say run it through the frig to get it cold first ..LOL
K/N Cool intake air
Duel power exhaust
Old 07-04-2009, 06:24 AM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
JB Weld makes a product specifically to repair tanks and pipes. It's called "JB Water Weld". It cures over wet surfaces and even underwater. Great stuff!!!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-04-2009, 06:35 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Howie nailed it, with some polyurethane on the washer, it worked for over 10 Seasons on our Safari.
"Keep it stupid....simple".....H.C.C.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 07-12-2009, 11:00 PM   #19
dwayne423's Avatar
jacksonville , Florida
What nobody's going to suggest MIGHTY PUTTY ?
If your not having fun
your not doing it right.
dwayne423 is offline   Reply With Quote
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 04:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 02:23 PM
Black tank to outhouse hole? davida Waste Systems, Tanks & Totes 22 12-06-2006 08:42 AM
Oh no! I drilled my holes to big. What now? HamiBambi Ribs, Skins & Rivets 8 05-30-2006 09:40 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 07:44 AM
