Old 05-09-2009, 07:11 AM   #15
94Tri's Avatar
1994 34' Excella
Mount Vernon , Kentucky
I have seen a bunch of great ideas here. I would go along with the two part epoxies made for patching gas tanks, etc. It cures fast and is impervious to liquids. Walmart carries it.
94Tri is offline   Reply With Quote
Old 05-17-2009, 08:18 PM   #16
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Originally Posted by markdoane View Post
Go to your local home supply store and buy a coil of 1/4" polyethylene tubing. Insert the tubing through the hole and route the tubing up behind the gaucho.
Fill the water tank with beer.
Insert the other end of the tubing into your mouth, recline on the gaucho. Enjoy.
I was going to say run it through the frig to get it cold first ..LOL
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 07-04-2009, 05:24 AM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
JB Weld makes a product specifically to repair tanks and pipes. It's called "JB Water Weld". It cures over wet surfaces and even underwater. Great stuff!!!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-04-2009, 05:35 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by HowieE View Post
Since it is o the top of the tank and will never see any pressure and you can get to it through the 2 1/2 in hole i would just use a Boiler Plug. They are self tapping screws with a rubber washer.
Howie nailed it, with some polyurethane on the washer, it worked for over 10 Seasons on our Safari.
"Keep it stupid....simple".....H.C.C.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-12-2009, 10:00 PM   #19
dwayne423's Avatar
jacksonville , Florida
What nobody's going to suggest MIGHTY PUTTY ?
If your not having fun
your not doing it right.
dwayne423 is offline   Reply With Quote
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Black tank to outhouse hole? davida Waste Systems, Tanks & Totes 22 12-06-2006 07:42 AM
Oh no! I drilled my holes to big. What now? HamiBambi Ribs, Skins & Rivets 8 05-30-2006 08:40 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
