04-02-2013, 11:25 AM
Airstream fanatic
Bouse
draining fresh water tank for travel???
Hi everyone
We have a 1979 31' Sovereign, and we have full hookups (the grey and black tanks are hooked up and open). We are getting ready to take off soon and we need to dump the fresh water tank, which according to the switchboard, its half full. Its located in the closet, but how do I dump it?? Thank you!!!!
04-02-2013, 11:34 AM
Normal
We would just run it through your systems and empty it via the holding tanks in the usual way. I.e. run the faucets and shower, flush the toilet til the fresh water tank is basically empty.
There is a little thingy on our hot water heater (outside) that you flip to drain that.
Maggie
04-02-2013, 11:35 AM
Alamo Heights
I don't know where your drains are located, but as a general rule you shouldn't leave the black tank open when you have full hookups. That can allow the liquids to drain away quickly, leaving solids to dry and harden and building what I've seen referred to as a "poop pyramid" that requires some effort to eliminate.
It's best to leave the dump valve for the black tank closed and empty it periodically.
— David
04-02-2013, 11:36 AM
Alamo Heights
Why, by the way, do you feel you need to dump the fresh tank? Has the water been in there forever and you just want to flush it? It can be useful to have some freshwater on board when traveling.
— David
04-02-2013, 11:59 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Butttttt, since you asked. Between the axels on the curbside ( drivers side ) wayyyy down low you should see a white plastic valve with a handle. It's probably in closed position now so grab it and twist it to the open position. It may be hard to turn with your fingers and there's no room to get any tools down there but you gotta do it. It may be old and brittle and, yes, it might break off. Then you gotta replace it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
04-02-2013, 12:41 PM
1995 34' Excella
Pembroke Pines
And replacing it is not fun nor easy
That's my task this week, to fix the leaking drain.
04-02-2013, 02:20 PM
2000 31' Land Yacht
Central
We usually drain fresh or add to if it is empty, like to travel with a 1/3 tank, would prefer less but command center show 1/3 as first led. Has been great, as enough water for flushing and if first stop happens to be a boondocking it makes it easy, until we get to a regular cg.
On reread your post, I would do as others have suggested, pump some into your black tank so that it will breakup the pyramid while you travel.
04-02-2013, 02:56 PM
I don't travel with partially filled tanks. I usually run fully loaded fresh water, but if running home I'll drain the tank.
Partially filled tanks tend to increase sway, if the tank is athwartship; or pitch, if the tank is fore and aft. It's called free surface effect.
Less of a problem the closer the tank is to the axle.
04-02-2013, 04:24 PM
Oswego
My tank is between the axles. BW and GW right behind the axles. I have always traveled with 15 gallons or so in the FW tank and whatever (not full) in the other two. Have never experienced any kind of behavior of the trailer (sway) whether it's empty or 20 or 30 gallons between the three tanks.
I do understand the principle of the surface effect, but in the modern center(ish) tanks of the AS layouts, I don't think it is a significant issue when sane driving habits are in play.
Edit: Also most of today's tanks are at and below the centerline of the axle shafts.
-Rich-
04-02-2013, 05:11 PM
Well, I'm happy to hear that. The tank in my trailer is located at the front behind the gaucho, so I notice its really squirrely if its half full.
I don't know where the tank is in a 1979 Sovereign, so I guess you're right.
If the tanks are close to the axle, it's less a problem.
04-02-2013, 05:21 PM
Oswego
I would think high is bad. High and rearward is worst. I was thinking of the older front/high tanks as I was typing my post above, but I THINK by '79 they were low and center....but not sure.
-Rich-
04-04-2013, 10:42 AM
Airstream fanatic
Bouse
OK, the fresh water has been in there for about a month, and we have half a tank... if I need to keep water in there, I should probably drain it and add new before we leave huh? Thanks in advance about the black water tank being open, I did not realize that. I'm still new to this whole Airstream travel business!
Well this could turn out to be interesting...
04-04-2013, 11:15 AM
2004 28' Classic
Midland
fresh water tank
A few drops of clorox in your FW tank will kill any bacteria that is growing there. We never drink the water coming from our FW tank, too much possibility of contamination from the tank, system, hoses, or the rv park water system.
04-04-2013, 12:33 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Yes, our drinking / cooking water is "jugged" along ... FW tank is just for washing hands/body with soap and rinsing the head after use.
04-04-2013, 12:41 PM
2004 30' Classic Slideout
Fenton
, Missouri
We carry a minimal amount of water when traveling. Enough for Patty to be able to use the toilet at rest or food stops. If are staying at a campground without water hookups at the site, I'll generally fill at a common spigot there unless we know that the water is skanky or has sediment.
I don't believe in carrying any more weight than necessary. A full freshwater tank on my Classic is near 500 lbs.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
04-21-2013, 11:00 AM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
We travel with some water in the tank. Sometimes full, sometimes less then full. If we are leaving in winter we refrain from charging the system until far enough south to avoid freezing. ( Don't ask ). Nice to have some water on board just in case. After our final night along the road I try to a very good clean \drain of the grey and black tanks. Upon returning home I always drain the fresh water tank. I don't want to leave water in the tank between trips. I do a periodic disinfecting of the fresh tank with bleach and I do drink the water except for the places where it has the "off taste". We usually carry a couple of gallons of bottled water for those times to drink and make ice. We've never had a problem with drinking the onboard water other than the occasions where it had an off taste. I usually taste the water if I can before I use it to fill the tank but sometimes you use what you have access to.
Roger in NJ
TAC - NJ 18
04-21-2013, 11:39 AM
Corona
Water tank level
The difference in fuel mileage is extremely small, even going cross country between a full and empty water tank.
When the tank is "FULL" your carrying a little extra insurance should you be out in the boonies and the tow vehicle decides to bust a radiator hose. Guess wher you can quickly get some water.
And then, the full tank also lowers the center of gravity so that the trailer tracks a little better.
And when mother nature calls, guess where you can find a quick potty?
And finally, should you decide that you have had enough for the day, spending time at a rest area is always nicer, when you have your own water, for cooking, showering, and just living.
Carrying full water is "NEVER" a liability, but the lack of it can become rather serious.
04-21-2013, 12:12 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
After "dumping", I add 4 toilet bowels of water and 1 packet of chemical. That way the toilet is always ready. The fresh, I have the separate filter for drinking. If I know that I will not be using the trailer for awhile, I drain it on the way home and refill just before the next trip. The Gray tank I add the cleaner 2-3 times a season. Soooo far no problems. This method was suggested by service department.
04-21-2013, 12:56 PM
2017 25' International
Los Osos
I've always like to know that my first tank of water is from my Culligan water softener.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
04-21-2013, 12:57 PM
2005 19' Safari
GLENDALE
, AZ
We always travel with the fresh water tank full -- You never know when you'll find a great boondocking spot!
Also, water makes a big difference if you break down in the desert. Even when we aren't towing, we carry extra water in a seven-gallon portable tank in the bed of our pickup.
