Old 05-13-2010, 08:30 AM   #1
1978 31' Sovereign
Bluffton , South Carolina
Unhappy Draining fresh water tank?
How do I drain the fresh water tank? I filled it by accident in hast! The inlet is just above the port(left) side wheel wells. 78 Sovereign rear bath.
FishHouse is offline   Reply With Quote
Old 05-13-2010, 09:11 AM   #2
jgsimons's Avatar
2005 19' International CCD
Big Spring , Texas
my advice is to open your cold and hot water taps at kitchen sink, then power up your water pump and allow it to push the stored water through piping until supply is exhausted. opening the hot water tap should also allow for any water in hot water tank to be push out as well.
jgsimons is offline   Reply With Quote
Old 05-13-2010, 09:52 AM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Some late 70s models hide the drain up above a roughly 12x12 steel plate in the center of the tank, out in the center of the belly pan. This is a true unbelievable stupidity. My 77 Safari is like that. You take the plate down by removing a large bolt in the center of the plate.
If you've got shore power, it's probably easier to empty the tank using the pump , per JGSIMONS suggestion.
Zep
Old 05-13-2010, 01:59 PM   #4
Ottawa , ON
Just a suggestion b4 you take anything apart: on my rear-bath Sov, there are three taps in the floor of the cabinet containing the furance and sink, between those two units.
One of those drains the fresh water tank.
It may be different on your unit, of course...
Draining the fresh water tank???? Joebanjo Plumbing - Systems & Fixtures 6 11-28-2010 08:30 AM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Draining Fresh Water Tank psundstrom Fresh Water Systems 2 10-15-2007 07:37 PM
New member- Water Tank Not Draining jvandal Fresh Water Systems 6 11-10-2006 11:17 AM
Water Tank Draining trippy 2007 Safari 1 09-13-2006 07:31 PM
