Originally Posted by eddo
Have a 1973 Safari that I purchased recently and have bin resolving leaks do to frozen copper pipes. I believe all the leaks have been repaired. I closed the two valves under the bathroom sink and three valves under the galley. Turned on the city water and it is pouring from a hose under the trailer by the galley. It sounds like it is coming from the water heater. Is there a drain valve in the water heater that is open and if so where is it. Regards, Eddo
if it was the water heater itself, you'd see it coming out the water heater door; not underneath the trailer. (unless someone modified something on your trailer...or mine, for that matter!
the only other way out of my water heater is through the lines that feed it...which would be through those valves under the galley. On my trailer, those 3 valves are tied together to a single drain line that sticks out through the belly pan. (3/8ths copper pipe). I suspect that one of those valves is not really closed all the way, or is busted.
