Old 01-06-2010, 12:58 PM   #1
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Drain Valve Locations
The fresh water drain valves on a '92 Excella Limited are not location per the manuel.
The manuel shows three under a false bottom panel in the cabinet below the microwave. Not there! Only a heater duct hose which cannot be moved.
Fourth valve located under the roadside twin bed, per the manual. Not there. They are not on the end of the drain lines under the fresh water tank.
I will appreciate information to help me find the valves.
jlovelady is offline   Reply With Quote
Old 01-06-2010, 07:00 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Bump!
Any late 80s to mid 90s Limited owners recognize this problem?
5 meter Langford Nahanni
Old 01-06-2010, 07:31 PM   #3
1989 32' Excella
Limestone , Alabama
Our 1989 32' Excella has the 3 drains under a false panel in the bottom of the kitchen sink cabinet and from (occasionally faulty) memory the 4th was under the road side twin.
Steve
war eagle is offline   Reply With Quote
drain valve, location of valves
System drain valve? Hawkeye5 All Argosy Trailers 6 05-16-2008 06:22 PM
'77 Excella - Looking for Drain Valve DesertRat 1977 Excella 500 15 02-14-2008 05:22 PM
Water drain valve? ldetsf LP Gas, Piping, Tanks & Regulators 2 11-29-2006 04:57 PM
Electric Drain Valve? Walt74wra8 Plumbing - Systems & Fixtures 2 11-29-2006 04:04 AM
Drain valve too low wayner1239 Waste Systems, Tanks & Totes 3 02-18-2003 11:45 AM
