Old 04-30-2013, 09:36 AM   #1
1980 25' International
Napanee , Ontario
drain valve location
Help. I cannot find a drain valve for the FW tank on the outside or the inside. 1980 International 25' with FW tank between axles. Any chance that it never had one?
Airnap is offline   Reply With Quote
Old 04-30-2013, 09:57 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Not likely....
I don't they would have moved the location, the white plastic is the tank drain, the two petcocks the low point drains for the lines, check here, streetside between the wheels.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-30-2013, 01:00 PM   #3
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
My '97 Safari is in the same location as shown in Robert Cross' picture.
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Old 05-01-2013, 08:27 AM   #4
Napanee , Ontario
I have not seen anything like that under my tank but I will take another look!
Old 05-25-2013, 10:15 AM   #5
1977 21' Globetrotter
Davis , California
Maybe check in the less visible corners of the trailer, such as under the vanity. On my 21' Globetrotter (1977) there are two, under the vanity in a relatively inaccessible corner of the trailer... Hope that helps.
flyflinger is offline   Reply With Quote
Old 05-25-2013, 11:49 AM   #6
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I don't believe you have a freshwater tank drain on your 1980. It came later. We had to use pump to empty FW tank through the 70s and into the 80s. 1985 sticks in my mind, but it could be an FRM (false recovered memory).
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
