Old 03-02-2010, 06:43 AM   #1
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Drain plug and notch
Any suggestions on replacing the drain plug with some sort of valve on the fresh water tank? What is the purpose of the 6" x 9" notch in the tank? There is an inspection plate screwed to the bottom of the pan to access the notch.
ID:	97221   Click image for larger version
Birdwell57 is offline   Reply With Quote
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Tool to remove fresh water drain plug willbrackman Fresh Water Systems 5 06-19-2009 10:44 PM
WH drain plug- winterizing??? crazylev Water Heaters, Filters & Pumps 14 10-21-2008 10:13 AM
Needed, drain plug for hot water tank! wacnstac Fresh Water Systems 8 10-16-2007 08:22 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
