Drain petcock replacement '09 International
On a trip to Alaska this summer, some rocks from a gravel "highway sheared off the fresh water drain petcock on our 2009 25' International CCD. The only piece left was the plastic flange. I removed the 2 screws and tried to pull the remaining piece from the back side of the flange into the tank with pliers and met with no success. Any suggestions would be greatly appreciated. I found another thread and it talked about enlarging the hole in the tank, but, I'm leery of doing that. Once the old piece is removed, what would be the suggested sealant to re-seal the valve to the tank?
I had to use some RTV to seal the petcock on the trip so that we could continue to use the fresh water tank on the 3 month trip. I was surprised that it held for about 7,000 miles of driving.
THANKS for any help that can be provided!
