Old 07-14-2016, 10:05 PM   #1
1962 22' Safari
FARMINGTON HILLS , Michigan
Drain on bottom of 1962 Safari
Renovating a '62 safari. when I tried filling up the fresh water tank, saw that the water was just draining out a small hole in the bottom of the trailer which, when I looked in it, appeared to be some kind of valve but it did not appear to have any type of shut off (see pictures). Not sure what this is since there is another drain valve close to it that clearly is a main fresh water drain. anyway...can't fill my water tank till I figure this out.
Does anybody know what this is or if it is necessary?? (I'm thinking of bypassing it with a new pipe)
doug1962 is offline   Reply With Quote
Re working kitchen drain- pex for drain lines?? Bwilson11 General Repair Forum 4 04-20-2014 09:42 PM
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 12:23 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
