Old 12-11-2007, 06:25 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Does this appear to be a good fresh water tank?
Does this appear to be a good fresh water tank?........thanks
eBay Motors: Fresh Water RV Trailer Camper Holding Tank 30 Gallon (item 170173484192 end time Dec-26-07 06:39:47 PST)
toastie is offline   Reply With Quote
Old 12-11-2007, 06:30 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by toastie
Yes, it does. It should be used exactly as it is pictured though, or on it's side with the large fitting on top to give you fill, vent on top, a suction port on the bottom, as well as a drain port on the bottom. It is polypropylene, so fittings should be "spun" in with a high speed router. Looks like a nice tank if it fits your application.
Uwe
www.area63productions.com
Old 12-11-2007, 07:28 PM   #3
toastie's Avatar
1955 22' Safari
How does one apply the fitting with a router.........thanks
Old 12-11-2007, 08:56 PM   #4
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
If the tank works for you in one of it's two positions, then you will not have to change any fittings.
The router has a special adapter, that holds the poly fittings. Then, spinning the fitting over a pre-drilled hole of the correct size into the poly at high speed melts it into the tank without the use of any glue or sealant.
Uwe
Old 12-11-2007, 09:34 PM   #5
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
If you need the fitting locations changed you should be able to get that done at a local RV repair shop. I don't know what they charge but the last time I had it done it was $20 with no receipt .
The price is certainly decent if you can accommodate that size/shape of tank.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 12-11-2007, 10:21 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I just received one from the same guy this week and was very impressed with the quality. Good thick walls, quick shipping (and can't beat the price) and very versitile setup with inlet and multiple outlets.
goransons is offline   Reply With Quote
Fresh Water Tank ??'s kevino Fresh Water Systems 28 08-26-2007 06:25 PM
Fresh water tank nilesrob Fresh Water Systems 4 09-16-2006 09:17 PM
Fresh Water Tank Bett Walker Fresh Water Systems 0 05-23-2006 05:30 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Fresh water tank Devoman Fresh Water Systems 9 08-26-2005 08:10 PM
