Old 12-17-2015, 05:41 AM   #1
1976 25' Tradewind
Sulphur , Louisiana
Do you tow your AS with a full fresh water tank?
I'm not planning on boondocking anytime soon. Just purchased a tradewind that was hooked up to city water at an RV park for at least 6 months. Finally found out how to drain the fresh water tank. It's still pumping out. What's the estimated capacity? That's got to be at least a thousand pounds of old water I just pumped out.
Bobkatbry is offline   Reply With Quote
Old 12-17-2015, 05:46 AM   #2
1976 25' Tradewind
Sulphur , Louisiana
Maybe not a thousand but it's at least 500 if my finger counting calculator is correct.
Old 12-17-2015, 06:32 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
8.3 pounds/gallon for water and I doublt if the capacity is more than 30 gallons.
I replaced the missing factory fresh tank in mine with a 30 gallon but I never fill it full. I keep 8-10 gallons in it for flushing the toilet while stopped for lunch.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 12-17-2015, 06:38 AM   #4
Long Island , New York
"A pint's a pound the world around . . . "
Old 12-17-2015, 07:03 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Close enough. A US gallon of water is 8.344 pounds, so a US pint is 1.043 pounds. Only engineers need that level of precision, so yeah, a pint's a pound, and a gallon is 8 pounds.
I've traveled with a full on-board water supply when I was headed out to a campground without a water hookup, with no ill effects because full tanks did not put me over my Airstream's gross weight rating. But if I'm headed to someplace that has potable— and palatable— water, there's no point to carrying the extra weight.
I would suggest, however, that you travel with tanks full or tanks empty, but not anything in between. Shifting weight due to water sloshing around in a partially-filled tank will not do your tank's mounting brackets any favors.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-17-2015, 08:08 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Simple answer, my fresh water tank is kept full. Water is drained and replaced monthly or as needed.
MICHAEL
Old 12-17-2015, 08:37 AM   #7
mandolindave's Avatar
For me.full or empty
Don't know your unit but
You might not have to pump the water out ( although I have ) There might be a drain.
mandolindave is offline   Reply With Quote
Old 12-17-2015, 08:43 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Trailer stability is a good reason to travel with the water tank full. We couldn't have a better place to put 250 lbs than in the water tank, low and between the trailer axles.
And in our travels, our plans remain flexible as we move about the country. If we have a full water supply we are not limited to where we may decide to stop for a few days.
Doug and Cheryl
Old 12-17-2015, 08:49 AM   #9
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I would think your coach has the same tanks as mine. If so the fresh water is 40 gallons, black and gray tanks are 10 each. Hope this helps.
Flynavy is offline   Reply With Quote
Old 12-17-2015, 09:45 AM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I travel with the fresh water at least 1/2 or more full. I do not see a down side to doing this with a trailer and I like having water when we stop for lunch or other breaks. I do keep the waste tanks fairly empty when I can. Have weighed the trailer when we are traveling several times and the axle load has been under the max.
Old 12-17-2015, 10:00 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Yes...until it's empty, then we fill it again.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-17-2015, 12:33 PM   #12
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
No problem filling it before you head out. It's designed to be full during towing and it sure is nice having that water there if you need it along the way or when you get there
kdickinson is offline   Reply With Quote
Old 12-17-2015, 12:36 PM   #13
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Mine are full only if planning on boon docking. Usually only keep 5-10 gallons in the tank for quick hand washes or whatever when traveling.
TinCan
graysailor is offline   Reply With Quote
Old 12-17-2015, 12:52 PM   #14
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
We always top off the water tank when heading out from somewhere that has running water . We seldom have a place pre planed for the next night and are likely as not run across a boondocking site for the next night or two.
I like that old saying about it's better to not need it and have it , than to need it and not have it .
As well as a full tank of water in the trailer, we also carry a couple of 7.5 gallon water jugs in the Dodge. They came in handy a few times on our two month road trip to Alaska and back , with most nights spent boondocking. And they work just fine as a way to refill the fresh water tank while staying for an extended time in National Forest campgrounds where the potable water spigots are sparsely dispersed near the out houses. With the help of a little fold down hand cart.
There is no noticeable effect on the diesel usage or stopping ability with or without the extra weight of the water .
Just Saying :-)
dannydimitt is offline   Reply With Quote
Traveling with a full tank of fresh water? J&J AIR Fresh Water Systems 23 04-30-2015 05:38 PM
If you're gonna boondock, when do you fill up your fresh water tank? cantdrv55 Boondocking 23 04-24-2015 09:40 AM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
Driving with fresh water tank full - is it OK? bovk Fresh Water Systems 72 10-07-2013 02:56 PM
Do you drink your fresh water tank water? pageclot Fresh Water Systems 81 09-03-2009 09:56 PM
