12-17-2015, 02:14 PM
#21
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay
Do You Tow Your AS With A Full Fresh Water Tank?
Originally Posted by SeaLevel
Not all of Florida. We have a very good water system in Jupiter, which utilizes both reverse osmosis and nanofiltration.
Same improvements here in the Tampa Bay Area.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
12-17-2015, 02:59 PM
#22
2013 30' Classic
Greenwood
, Mississippi
Sometimes. It seems to tow a lot more smoothly with a full water tank.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-17-2015, 03:04 PM
#23
2014 27' Flying Cloud
Stowe
, Vermont
Most of the time when we travel it's on multi day trips, so having a full fresh water tank is the way to go for us. 1. We like using our bathroom rather than a highway rest area. 2. We can take showers when needed. 3. We eat using our galley. Many of our nights are at Walmarts, Cracker Barrels and truck stops. When we need dumping tanks, more water, etc. it's on to a campground.
12-17-2015, 03:15 PM
#24
2000 30' Excella
2014 30' Classic
Princeton
, Iowa
Magic
I need you as Bar Tender, I can only get a pint out of a pint. I travel with what ever is needed in my tanks.
12-17-2015, 03:32 PM
#25
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
We've learned that a full water tank is (for us) the way to go. We can hang in with marginal everything, EXCEPT water. So, unless there's some overriding reason not to, we pull out with a full water tank every morning we're on the road.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
12-17-2015, 03:41 PM
#26
1977 Argosy 28
Euless
travel with water in the tank
I always travel with a full water tank and empty black and grey tanks. My water tank is in the front, black and grey are behind the axles and my tongue weight is on the light side.
I have camped at 2 campgrounds where the water pressure was so high it caused problems even with a pressure regulator on the hose. At one they even used it as a reason to try sell regulators. I don't know how high it was but the pressure defeated the hose regulator, the pump check valve, filled up the water tank and water was running out the fill door. It also bulged the reinforced flex hose to the pump and started leaking at the connections.
I no longer hook up to city water and just refill the tank with the hose when necessary and run off of the pump. I like water from home better and we practice water conservation even with hookups which makes it 2nd nature when we don't have them.
12-17-2015, 03:54 PM
#27
2007 28' International CCD
Springfield
, Missouri
A Airstream is designed to tow with a full tank.
12-17-2015, 04:01 PM
#28
2013 27' FB Eddie Bauer
Salado
I have checked mpg with full and empty water tanks on my 27' Eddie Bauer and found no measurable difference. I also have found that sometimes having that extra water is a really good idea. We had a breakdown and spent three days in the vacant lot next to the dealership. If we had been traveling with empty tanks we would have had to spend them in a motel, eating in restaurants. Instead we were comfortably in our "silver Twinkie" (as my wife calls it) eating home cooking and enjoying the experience (relatively).
12-17-2015, 04:04 PM
#29
2010 28' Flying Cloud
Lower Alabama
, USA
Do you tow your AS with a full fresh water tank?
Yes, far better than having 5 or 10 gallons hammering to and fro and side to side. The tank has no baffles.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
12-17-2015, 04:24 PM
#30
2022 Atlas
Homosassa
We always travel with a full tank of fresh water and about 5 gallons in the black and gray tanks. We don't want the black and gray tanks to get dry and the small amount of sloshing will be good for them.
12-17-2015, 05:11 PM
#31
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Full fresh water tanks and several gallons in each of the black and gray tanks with the chemicals. That works for us and allows for contingency stopping if we need to.
12-17-2015, 05:18 PM
#32
Livingston
, Full time traveler
After 15+ years full-time, I know that RV campground water can be unreliable. Full tank also, I have been told by experts, dampens road shocks to trailer. I'm certain this latter comment can be argued, as with tires, etc.
Airstream of Consciousness
12-17-2015, 08:26 PM
#33
Proud Owner Vintage SBB
Santa Monica
Originally Posted by TBRich
Always travel with a full tank .. but then the tank on a 19' Bamrbi is not that big! .
My 15' Airlight has a 12 gal fresh water tank. We use it to flush the commode to wash up.
12-18-2015, 08:14 AM
#34
2003 31' Classic
Terra Alta
, West Virginia
Generally full on fresh till on our way home then let it go down as we travel home. But always a few gallons in black tank to slosh with treatment. Never in 40 years had a problem. Diesel TV doesn't care either way. Handy to have the convenience.
12-18-2015, 08:26 AM
#35
1977 31' Excella 500
West Sacramento
I always tow with my water tank full which insures trailer stability when towing as it puts more weight between the axles and the tongue. I also keep it full for disaster preparedness here in California where an earthquake, fire or flood is possible.
12-18-2015, 11:19 AM
#36
2014 25' FB Flying Cloud
Palestine
Once, going to a campground I was familiar with, that has tasty water, I didn't fill (just that 5 gal or so like some recommend). Picked up a friend at the airport in Little Rock (plane was late). Arrived after dark in a rainstorm. Water to the campground was off for a couple of days (repair). Never made that mistake again. I travel full. Drain when I return home.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
01-22-2018, 09:59 AM
#37
2007 23' Safari SE
Annandale
, New Jersey
Have always heard tanks need to be full or empty due to weight shift from sloshing ?
So we travel empty in the tanks, but always have a case of water bottles stored on board for emergency use and have never been left wanting.
I also carry either one or two 7gallon jerry jugs empty, so if we do get stranded, its easy to go fill up the jugs. If I do that twice, I pretty much have a full fresh tank.
01-23-2018, 06:39 AM
#38
Stowe
, Vermont
We travel with full water tank, and it's there for whenever we need it - drinking, washing, toilet, etc. We do a lot of long distance driving - VT to FL - VT to WY & CO etc. and do many overnights in Walmarts, Cracker Barrels, etc. It 's nice to have your "house" stocked with your basic needs, and what's more important than water.
01-23-2018, 07:34 AM
#39
2017 25' International
Niagara-on-the-Lake
, ON Canada
We travel with a full fresh tank (29 US gallons) so that we have potable water for drinking, washing etc. no matter where we stop. I have noticed that the gas mileage does not drop having the full tanks as once you get the rig rolling at speed it doesn't take much energy to pull the water too. I have also noticed that the whole rig is more stable with the weight of the water low and centred on the axles.
Ray B.
01-23-2018, 08:14 AM
#40
Tampa
No. I don't want to drag around another 300 pounds.
I keep enough for a few days of dish washing and showers.
