Old 12-17-2015, 04:04 PM   #29
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Do you tow your AS with a full fresh water tank?
Yes, far better than having 5 or 10 gallons hammering to and fro and side to side. The tank has no baffles.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 12-17-2015, 04:24 PM   #30
2012 30' Classic
Homosassa , Florida
We always travel with a full tank of fresh water and about 5 gallons in the black and gray tanks. We don't want the black and gray tanks to get dry and the small amount of sloshing will be good for them.
Tater is offline   Reply With Quote
Old 12-17-2015, 05:11 PM   #31
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Full fresh water tanks and several gallons in each of the black and gray tanks with the chemicals. That works for us and allows for contingency stopping if we need to.
Old 12-17-2015, 05:18 PM   #32
HCR
HCR's Avatar
Livingston , Full time traveler
After 15+ years full-time, I know that RV campground water can be unreliable. Full tank also, I have been told by experts, dampens road shocks to trailer. I'm certain this latter comment can be argued, as with tires, etc.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 12-17-2015, 08:26 PM   #33
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Originally Posted by TBRich View Post
Always travel with a full tank .. but then the tank on a 19' Bamrbi is not that big! .
My 15' Airlight has a 12 gal fresh water tank. We use it to flush the commode to wash up.
'55 Airlight is offline   Reply With Quote
Old 12-18-2015, 08:14 AM   #34
2003 31' Classic
Terra Alta , West Virginia
Generally full on fresh till on our way home then let it go down as we travel home. But always a few gallons in black tank to slosh with treatment. Never in 40 years had a problem. Diesel TV doesn't care either way. Handy to have the convenience.
wvstreamer is offline   Reply With Quote
Old 12-18-2015, 08:26 AM   #35
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I always tow with my water tank full which insures trailer stability when towing as it puts more weight between the axles and the tongue. I also keep it full for disaster preparedness here in California where an earthquake, fire or flood is possible.
4RXLA is offline   Reply With Quote
Old 12-18-2015, 11:19 AM   #36
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Once, going to a campground I was familiar with, that has tasty water, I didn't fill (just that 5 gal or so like some recommend). Picked up a friend at the airport in Little Rock (plane was late). Arrived after dark in a rainstorm. Water to the campground was off for a couple of days (repair). Never made that mistake again. I travel full. Drain when I return home.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 01-22-2018, 09:59 AM   #37
2007 23' Safari SE
Annandale , New Jersey
Have always heard tanks need to be full or empty due to weight shift from sloshing ?
So we travel empty in the tanks, but always have a case of water bottles stored on board for emergency use and have never been left wanting.
I also carry either one or two 7gallon jerry jugs empty, so if we do get stranded, its easy to go fill up the jugs. If I do that twice, I pretty much have a full fresh tank.
Fred L is offline   Reply With Quote
Old 01-23-2018, 06:39 AM   #38
2014 27' Flying Cloud
Stowe , Vermont
We travel with full water tank, and it's there for whenever we need it - drinking, washing, toilet, etc. We do a lot of long distance driving - VT to FL - VT to WY & CO etc. and do many overnights in Walmarts, Cracker Barrels, etc. It 's nice to have your "house" stocked with your basic needs, and what's more important than water.
VT Wanderer is online now   Reply With Quote
Old 01-23-2018, 07:34 AM   #39
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
We travel with a full fresh tank (29 US gallons) so that we have potable water for drinking, washing etc. no matter where we stop. I have noticed that the gas mileage does not drop having the full tanks as once you get the rig rolling at speed it doesn't take much energy to pull the water too. I have also noticed that the whole rig is more stable with the weight of the water low and centred on the axles.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 01-23-2018, 08:14 AM   #40
Mollysdad's Avatar
No. I don't want to drag around another 300 pounds.
I keep enough for a few days of dish washing and showers.
Mollysdad is online now   Reply With Quote
Old 01-23-2018, 03:44 PM   #41
dznf0g's Avatar
Oswego , Illinois
No more than 1/2 tank....unless my next stop is dry camping with nowhere to fill.
-Rich-
Old 01-23-2018, 04:09 PM   #42
2007 22' International CCD
This is what we typically do.. Carry enough water for flushing toilet and washing hands while on the road, lunch stops, etc. Dogs and humans have access to bottled water for most drinking uses.
Don't seem to have a sloshing problem, but the ProPride may be suppressing that...
Our dogs, in particular, will have digestive issues unless we keep their water supply the same--bottled water seems to work best.
Boondocking or cold weather, we run on a full fresh tank to prevent shore water hose from freezing..
KE4GNK/AE
Traveling with a full tank of fresh water? J&J AIR Fresh Water Systems 23 04-30-2015 05:38 PM
If you're gonna boondock, when do you fill up your fresh water tank? cantdrv55 Boondocking 23 04-24-2015 09:40 AM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
Driving with fresh water tank full - is it OK? bovk Fresh Water Systems 72 10-07-2013 02:56 PM
Do you drink your fresh water tank water? pageclot Fresh Water Systems 81 09-03-2009 09:56 PM
