Old 06-23-2006, 05:41 PM   #1
1964 22' Safari
Scottsdale , Arizona
Do Tanks Breathe
PO removed the fresh water tanks and I am left with a exterior fill hole and a cut copper line at the floor. My questions..... once the tank is installed and the system is sealed, what allows it to breathe once the water is pumped thru the lines and the tanks start to empty? Do water tanks have vents that will let air in and wont let any water out?
achip is offline   Reply With Quote
Old 06-23-2006, 05:48 PM   #2
Killo1's Avatar
2005 22' Safari
Santa Ana , California
I believe there is a breather hole near the filling area for the freshwater tank.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Old 06-23-2006, 05:58 PM   #3
Pressurized water systems do not breathe.
Demand systems must breathe or the plastic tank will collapse.
Old 06-23-2006, 06:08 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Your profile does not indicate what model or year you own. My 63 originally had a cylindrical metal tank under the bed and was an air pressurized system. Obviously it could not breath or it would not work. I converted it to a water pump system and put in a vent. My 77 was a water pump system and air entered thru the the vent next to the filler nozzle area to allow the water to be pumped out. When you fill the tanks you can hear the air rushing out of the vent.
Old 06-23-2006, 06:27 PM   #5
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Andy -
How does the system in my '64 breathe? What you said makes complete sense, but I haven't seen anything that appears to be a vent - as a matter of fact, if I fill it to rapidly, it "burps" the water right back out the filler neck when the water displaces the air in the tank.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-23-2006, 06:45 PM   #6
Originally Posted by GreatPumpkin
Andy -
Your filling the water tank way too fast.
You will rupture the tank the way you described that you fill it.
Take your time.
Your system, if I remember correctly, since you have a plastic tank, vents through the filler cap.
Old 06-23-2006, 06:51 PM   #7
Images: 70
Take your time.
Thanks - I learned to fill slower the first time I tried to fill it - I was standing directly in front of the fill spout and got quite wet It only took once to figure out to turn the water down and fill slower
I'll have to take a closer look at the filler cap.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-23-2006, 07:04 PM   #8
1964 22' Safari
Have no profile yet (1964 safari 22') Don't see a place in the fill area for a vent. Do they make a cap that breathes?
Thanks for the help
Old 06-23-2006, 07:07 PM   #9
1964 22' Safari
ANDY
What does your filler cap look like? My cap is a black ABS 2"
Old 06-23-2006, 07:11 PM   #10
Images: 70
My filler cap is solid, no vent holes. It is solid metal, says "vise grip" on it.
However I just took a closer look at my tank and mine has a copper line coming out the top and routing out the floor, so I'm assuming thats how mine vents.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-23-2006, 07:23 PM   #11
1964 22' Safari
That makes perfect sense..NOW I have a plan.
Thank You
Old 06-24-2006, 05:07 AM   #12
1977 31' Sovereign
1989 34' Excella
If the 64 originally had a air pressurized system rather than a water pump (as my 63 did), the copper vent line had a hand tightenable plug in the end of it up by the filler cap area on the outside of the trailer. You removed the plug when you filled the tank and then put both the plug and the filler cap back on and pressurized the tank with air (if you were at a fill station with access to compressed air) or waited till you got to the campground and let the on board compressor pressurize the tank.
Old 06-24-2006, 07:25 AM   #13
Images: 70
I think by '64 they had switched over to the on-demand system with the PAR pump. (at least that's what was in mine - I've learned that sometimes there were no hard fast rules back then)
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-24-2006, 10:00 AM   #14
ANDY
What year trailer do you have?
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
