Old 06-24-2006, 10:15 AM   #15
1964 22' Safari
Scottsdale , Arizona
I have a 1964 Safari
achip is offline   Reply With Quote
Old 06-24-2006, 10:46 AM   #16
Your tank is vented by a tube that is plumbed into the top of the water tank.
Could be plastic or copper.
Old 06-24-2006, 12:02 PM   #17
1964 22' Safari
Andy,
My tanks were removed by PO, so I have no idea what was there. I want to install a small plactic type tank. On your web site I saw a filler cap for a 1965 AS that has an air breather formed into it. Your cap is a female, my existing cap is a 2" ABS male. Would your cap work with an adapter? and allow proper air supply? When the trailor is not in use I assume all supply lines need tobe drained. If a small amount of water remains in the fresh tank is that a bad thing? (I assume the pump will not suck the water tank dry) Or do I need to install a drain in the bottom of the fresh water tank? (hoping I don't)
Thank You
Chip
Old 06-24-2006, 01:47 PM   #18
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Andy,
......Or do I need to install a drain in the bottom of the fresh water tank? (hoping I don't)
Thank You
Chip
Definitely need to be able to drain the tank. Why? 1) drain the weight 2) keep it fresh 3) flushing/cleaning 4) winterizing 5) etc.
Picture this - you leave it sitting for quite some time without use. Summer: you will soon be growing your own algae farm. Winter: the large ice cube will expand beyond the limits of the tank, rupturing it. Spring: the ruptured ice cube melts all over the inside or your refurbished trailer.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-24-2006, 02:44 PM   #19
1964 22' Safari
Great Pumkin,
I understand that the tanks need to be empty. After all the water has been pumped out I expect there is a small amount of water the pump has left behind. Is that small amount of water a serious problem.
Chip
Old 06-24-2006, 04:38 PM   #20
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Scottsdale does not get that cold. You may be able to do without anitifreeze. If you are worried, pour in a small amount in December and fill and purge the tank with fresh water in the spring. You should sanitize your tank at least once a year with bleach anyway.
Old 06-24-2006, 11:41 PM   #21
Images: 70
I guess I didn't pay attention to your profile to see you are in Scottsdale, AZ
dwightdi is probably right - I doubt you'll have to worry about freezing (although I did hit a whiteout, blinding snowstorm in Northern AZ once)
But even the small amount left in the tank could grow algae, depending on the conditions - I'd say you've got the right conditions for that (heat). Sanitizing the tank should help with that. Some even use a little bleach in the water throughout the season - do a search of the forum and you'll find directions on how to do that safely.
Do you know where Arivaca is? (They sell t-shirts that say you know you're lost if you find Arivaca ) I've got relatives there and Tuscon. Used to drive down every year from Oregon when I was a kid.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-25-2006, 07:15 AM   #22
1964 22' Safari
I spent a week in Arivaca one day. Dad and I had many hunting trips in the area. Patagonia, tombstone, bisbee, douglas a few of my favorite spot.
Thanks for the advice
See ya on the road
chip
Old 06-25-2006, 01:28 PM   #23
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
I replaced the original fresh water tank in my 64 Safari. Itís under the gaucho bed.
The original was nonpressurized and had a vent line on the top of the tank. The vent outlet runs to a T with a drain valve on one side, pump line on the other.
The fill plug is 2Ē metal screw in cap, looks like bung plug from a 50 gallon drum.
I replaced the tank (no telling WHAT had been growing in there for 40 years) with a new 40-gallon tank from original tank manufacturer. I can find the purchase info if you want it.
I drain it and rinse it after EVERY road trip so that no water is left standing in it except perhaps the small residual that doesnít drain. I occasionally run fresh water through it if it sits for very long.
I know about bio-growth and about freezing water damage!
Itís called a fresh water tank for a reason.
Safari 64
Safari64 is offline   Reply With Quote
Old 06-25-2006, 03:03 PM   #24
1964 22' Safari
Safari 64,
PO gutted gaucho bed, table area & water tank so i have no idea what was there or how it hook up. Where is your pump & switch located? And yes i could use info on water tank.
Chip
Old 06-26-2006, 12:18 PM   #25
Safari64's Avatar
1964 22' Safari
Hi Chip,
My water pump is located in the rear of the trailer, inside the ďone stop service centerĒ panel and to the left of the toilet. I replaced the original pump with a new (quiet) Shurflo pump. The pump switch is a simple toggle switch located on the bathroom cabinet wall (next to toilet seat). There are 2 switches there, one for water pump, one for bath exhaust fan.
The water tank fits under the gaucho bed frame slides.
I removed the original just ďbecauseĒ I like FRESH water.
The new one was slightly different shape but fits nice. I made new hold down brackets.
Water intake is on street side.
Vent line on top of tank.
Water outlet to rear.
I filled the new tank 5 gallons at a time, marking water level each 5 gals, making water sight gauge.
I also made carry brackets for 3 new style GI plastic water cans under the gaucho. That gives me 55 gallons fresh water on board.
There are several tank retailers on the web. One had a tank size calculator I used.
Iím not home now and without Airstream.
Busy catching and GPS collaring bears.
Iíll find the purchase info when I get home this weekend.
I can take a few photos of my gaucho/tank setup if that helps. As far as I know itís original 1964. I have side gaucho and front dinette. Refrigerator cabinet is at front end of gaucho.
Safari64
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
