Old 05-27-2011, 03:52 PM   #15
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Brian PEX is ubiquitous in the RV industry.
And it's working its way into other applications as well.
The simplicity of fitting pipes made of this material together is not only cost efficient, but anyone can do it with a minimal investment.
Spend some time looking at PEX videos, and I think you'll agree.
murreywalker is offline   Reply With Quote
Old 05-27-2011, 04:11 PM   #16
1985 31' Excella
Fresno , Texas
PEX is used in almost all new homes and apartments now. Homes are plumed now from a manifold usually in the garage and there are no more daisy chained plumbing feeds, each faucet or appliance has its own dedicated service that has a cut off valve at the manifold. If you get a leak somewhere it doesn't require everything to be shut off.
Wsmith is offline   Reply With Quote
Old 05-27-2011, 07:34 PM   #17
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used Flair It fittings throughout my trailer and they all work fine except for the Valve fitting. I found it does not prevent water from back flowing when shut off. Each valve has an arrow depicting the direction of flow and it will stop the flow from that direction. They do not stop the flow in the opposite direction.
I came across a ball valve at Menards and picked up 5 of them; plan to replace the Flair It valves with the ball valves.
I bought all of the Flair It fittings Online.
Old 05-27-2011, 10:28 PM   #18
bwbuer's Avatar
1968 24' Tradewind
Suffolk , Virginia
Sharkbites are the cats mow! And there valves are smooth as butter. They definitely not cheap but very well made and easy to use especially in tight spaces. Just my 2 cents from experience.
bwbuer is offline   Reply With Quote
Old 05-28-2011, 12:36 AM   #19
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my 2005 Safari has PEX and if you check out my blog, you will see what I had to do to change my bathroom faucet. I now carry the copper rings and the crimping tool, just because I have it now. As for parts, I would only carry a few feet of 1/2" PEX and a few brass connectors. I don't carry any parts because it is so easy to buy them at Lowes or Home Depot.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-28-2011, 06:57 AM   #20
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Bob - great blog, many thanks! - Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-28-2011, 07:30 AM   #21
2010 27' FB Classic
N/A , Texas
Thank You!
Old 05-28-2011, 09:37 AM   #22
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I wholeheartedly agree! SharkBites are 'da bomb!
Phrunes is offline   Reply With Quote
PEX Replacement CAN NOT BE DONE...'75 Tradewind... onemanclan Plumbing - Systems & Fixtures 40 04-16-2011 08:50 PM
'73 Argosy 24ft Plumbing Schematic?? suz272000 All Argosy Trailers 11 04-04-2011 10:54 AM
PEX Diverter?? wworx Fresh Water Systems 6 02-15-2011 01:28 PM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Installing Propane light lucymcdog LP Gas, Piping, Tanks & Regulators 69 01-22-2011 11:12 PM
