Old 07-20-2012, 10:54 AM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Hello all. I'm in the process of replacing the rear bathroom floor on my 69 ambassador and will be adding new holding tanks and 12 vlt pump. I've read and head Colin on the VAP talk about setting up the fresh water system so it ties into city water inlet. That way every time you hook up it fills you fresh water holding tank. I've been trying to figure out how to tie the systems together to make it work. I'm hoping to get some ideas and feed back on how to do it. I have attached a diagram of what i think might work. To fill the tank you would have to open one of the taps to let the air out, possibly the bathroom sink since it would be close.
Silverflames is offline   Reply With Quote
Old 07-20-2012, 11:12 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It's a matter of installing a bypass around the pump. Since the pump has a check valve to prevent water from flowing back thru the pump. The bypass valve should be in a convenient location since you will need to close it once the FW tank is full.
Old 07-20-2012, 11:49 AM   #3
1969 29' Ambassador
How would the air line be set up in that fashon?
Old 07-20-2012, 11:55 AM   #4
1988 32' Excella
Robbinsville , New Jersey
Your fresh water tank should already have a vent line so you would not need another one.
Old 07-20-2012, 12:08 PM   #5
1969 29' Ambassador
Yea don't have one, nor a pump. I'm having to start from scratch.. 3 new holding tanks, new rear floor, fire damage repair..
Old 07-20-2012, 12:28 PM   #6
1988 32' Excella
OK, well I believe you will need 1 mine has a small opening next to the fill cap for the vent line that stays open letting air out when filling and in when using/emptying. Opening a faucet wont let any air out of the freshwater tank, if it does that is the only thing the faucet would be good for.
