Old 05-02-2009, 06:33 AM   #1
mandolindave's Avatar
Crooked nipple
I have a leak at the plastic screw nipple coming out of my fresh water tank. When I found the leak, I went to tighten the nipple and noticed that the nipple was screwed in a little crooked. As I see it, here are my options
1) unscrew the nipple, apply teflon tape, reassemble
2) unscrew the nipple, apply abs glue, reassemble
3) unscrew the nipple, apply epoxy, reassemble
4) retap the tanks threaded opening for a larger nipple
What would you do? ( already searched for hours )
mandolindave is offline   Reply With Quote
Old 05-02-2009, 06:50 AM   #2
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Apparently, whoever installed the nipple, cross threaded it.
#4 is your best long term solution.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 05-02-2009, 06:55 AM   #3
I have never retapped plastic
Is heat involved in the operation. ( I sure dont want to ruin the opening to the tank )
Old 05-02-2009, 07:41 AM   #4
Kevin245's Avatar
If you're cross threaded you can pursue a couple of options. The first thing I would do is unscrew the fitting and visually inspect the threads of the tank.
I have seen instances where the threads were cut at a slight angle. This looked funny and is a reflection of poor craftsmanship, but is still functional. If yours is cross threaded and does not appeard to be badly damaged you can try to re-cut the threads as opposed to over tapping.
Otherwise...you will need to see if the tank can accomodate the next tap size and install a larger fitting, or goop the threads as mentioned in your post.
Plastic is fairly forgiving, and can be easily tapped. Use a good quailty tool, food grade oil for cutting, and take your time.
Regards,
Kevin
Eleanor Roosevelt
Old 05-02-2009, 01:00 PM   #5
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
We have no indication of your model nor the age of the water tank.
Is the nipple coming off the side or top or bottom?
Will you have "plenty" of room to do your working?
Is the surrounding poly brittle at all? If so removing the nipple becomes much more problematic doesn't it?
If you can get it out I'd certainly try to seal it first. Teflon tape or teflon daub-on.
Or I'd research what other thread sealing products are out there.
If it holds fine. If not the re tap as last resort.
Obviously you do not want to pooky it in there with some sort of cement that would make later removal totally precarious.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Crooked Door Chaplain Kent Classic Motorhomes 6 02-13-2006 01:33 PM
Crooked window/panel in 2005 Bambi? Bambi_Bandit 2005 and newer - Bambi all models 26 09-23-2004 10:50 PM
