Old 05-31-2011, 12:23 AM   #1
1997 34' Limited
christiana , Tennessee
Cracked pipe hard to get to. HELP.
I have a cracked pipe located behind the shower. Both shower and kitchen are on the same side. I can see the leak after I remove side panel under kitchen cab., but impossible to reach without removing entire length of cabinet. A friend suggested I remove shower but not sure how to do that. another suggested going through the bath itself. I would have to remove bath cabinet but I think I could reach it. Pretty tight with the wheel well and other pipes.
I have heard of others making an access panel in the shower itself using a dremel tool. Finally the last resort I feel would to put an access panel in the wheel well.
Can anyone tell me which is best?
Thanks everyone,
Clint
clint3636 is offline   Reply With Quote
Old 05-31-2011, 04:09 AM   #2
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
There may already be an access panel there. In our 1976 27' overlander, the bottom shelf in the wall cabinet next to the shower was (with some difficulty), removable, and I was able to access burst pipes behind the shower wall.
What model airstream do you have?
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 05-31-2011, 11:09 PM   #3
1997 34' Limited
1997 limited. To me the way to go would be through the bath sink but, the small opening under sink that shows the shower valve is small. Seems like I would have to take the whole sink cabinet out. Is that hard? I can try to download some pics but not sure how to put them on here.
Old 06-01-2011, 09:58 AM   #4
Ottawa , ON
Post #7 in this thread will give you help on how to post photos.
Old 06-01-2011, 05:09 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
If I had a broken water pipe behind the shower on my trailer, if it didn't feed something else by way of a "T" (none of mine do), I'd just replace the pipe from access point to access point, and abandon the broken pipe if I couldn't get it out. I imagine I could get it out piece by piece. In my world, the replacement could be a flexible braided hose.
My trailer is an antique, but it's designed with access to everything I've seen yet. Of course I'm redesigning the interior and my plan includes access without removal of builtins.
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 12:18 PM
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Leaking Sewer Pipe behind bathtub tamo2000 Waste Systems, Tanks & Totes 8 04-04-2011 10:20 PM
Water Hose - Hard Water Deposits Al - K4GLU Fresh Water Systems 4 02-16-2011 04:00 PM
abs plastic seams cracked rayandre Sinks, Showers & Toilets 5 02-15-2011 03:56 AM
