Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 04-13-2002, 07:27 PM   #1
ckeysor
WBCCI 11067 WDCU
ckeysor's Avatar
Profile:  1986 25' Sovereign
Atlanta , Georgia
Question Copper vs. PEX
I am purchasing a 1979 International that had a copper pipe rupture due to inadequate winterizing. Who would have known you had to winterize in Atlanta.
I am wondering if it would be better to replace the broken pipe with copper or the PEX piping? Which would be more durable? which is better from a restoration standpoint?
I appreciate the help.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 04-13-2002, 08:02 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
My understanding is that Pex can be problematic. My reccomendation is use copper and either seat it in or use brass compression fittings.
If you are trying to keep it original I would stay with the copper.
Just my 2 cents worth
I am sure that other forum members would be happy to share their experiences with you regarding this.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-14-2002, 09:14 AM   #3
ckeysor
WBCCI 11067 WDCU
ckeysor's Avatar
Atlanta , Georgia
thanks, glad to know it before I get started. The plumbing that needs to be fixed is in a very akward place. It will be a fun repair.
Thanks-again
Chris Keysor
WBCCI 11067
Old 04-14-2002, 09:49 AM   #4
thenewkid64
Just a member
Images: 21
Is the repair under the floor?
What Floorplan/layout do you have?
Do you have the service manual for your model/year?
I ask these questions so you can tap into the vast knowelge of our other forum members that may have had simalr problems.
Brett G
Old 04-14-2002, 05:18 PM   #5
83Excella
83Excella's Avatar
Profile:
Read the 'Plastic Plumbing' thread in this forum for more info on plastic.
John
83Excella is offline   Reply With Quote
Old 04-14-2002, 05:35 PM   #6
ckeysor
WBCCI 11067 WDCU
ckeysor's Avatar
Atlanta , Georgia
Brett,
The leak that I know of (it is such a big leak that the water is pouring out and not going anywhere else) is in the boot or trunk compartment. The pipe is on a cold water pipe leading to the shower. The leak is about 6-8 inches up past the boot door and is hard to reach.
The floor plan is the rear bathroom, full-size bed in the rear. I do have the owners manual.
Although the leak is in a tough place it is not impossible and at least I do not need to tear anything out.
Chris Keysor
WBCCI 11067
Old 05-19-2002, 10:18 PM   #7
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Question So is PEX better than the plumbing materials available at Home Depot?
I am about to re-plumb my entire trailer. What is the best type of plumbing to use? If possible I would like to use "standard" plumbing products available at Home Depot.
Is PEX really that good?
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 05-20-2002, 09:14 AM   #8
83Excella
83Excella's Avatar
Profile:
Andy,
Did you read the article I posted about plastic plumbing? Based on that article PEX has a limited lifespan, about 10-15 years before it starts breaking down and leaking. If it were me I would use the newer stuff and avoid the re-plumbing in 10 years.
John
Old 05-20-2002, 10:26 AM   #9
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
The materials and fittings at The Home Depot's in Houston are the Quest - PEX fittings that I have also found at Plumbing Supply Houses here.
To see every PEX fittings you would ever need, go to :
http://www.pexconnection.com
I especially like the color coded Red(hot) Blue(cold) tubing.
The materials are not that much in cost. It is the crimper that is expensive. I have used the 2 wrench block crimper to make good connections. It is just slow.
I spent a couple of hours looking through a number of Travel Trailers at a lot here in Houston looking under the sinks and behind the water heaters to see what was currentlly being used in new construction. Most had PEX with plastic fittings. All of the Airstreams I looked at (about 10 MH's) had copper fittings using a gray braid-reinforced tubing.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 05-21-2002, 04:24 PM   #10
Andy R
Administrator
Andy R's Avatar
Dallas , Texas
Images: 13
Lightbulb What new stuff John (83Excella)?
Are you talking about the new PEX "BESTPEX" colored tubing?
If not, what tubing are you talking about?
Old 01-17-2003, 05:23 PM   #11
hex
hex's Avatar
Profile:
Question Another hangin thread
I think this thread needs some further discussion.
So is Pex the answer or not?
What happens to it after the 10-15 years mentioned above?
I read somewhere on the forum here that copper was most prone to freeze bursting...Why? It seems that it would be the strongest and least prone
hex is offline   Reply With Quote
Old 01-17-2003, 06:40 PM   #12
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Copper is more prone to freezing problems because it is so rigid. It does not flex like the PEX does because it is copper. I replumbed my entire trailer with PEX. We'll find out soon enough if it is subject to drying out as other plastic and rubber products do here in the desert. Maybe I'll be replacing it in the next few years. Gawd, I hope not
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 01-18-2003, 07:22 AM   #13
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
I would rather have the copper. Yes, it will freeze swell and burst but it is much easier to work on. The pipe and fittings are easily available, you don't have to worry about it mysteriously popping apart and it withstands the heat much better. The only thing is I am pretty good at sweating copper since I have been doing hvac & plumbing work for quite a while so I guess I have a little more practice at it?
Chas
Chas is offline   Reply With Quote
Old 01-18-2003, 08:18 AM   #14
j54mark
Profile:
There appears to be no correct answer to the question, "which is better". There is a lot to be said for going with what you are comfortable with.
Pex has an unknown lifespan at this point. Copper is usually considered more or less permanent, but that does not necessarily mean in a trailer where there is movement and flexing going on. Pex has some incredibly high coefficient of expansion, which is great if water freezes and pointless if it does not.
I would be interested to hear from some expert on sweated copper fittings vs. soft copper tubing and compression fittings. It seems to me that sweated fittings would not be desirable in an envirionment subject to the stresses and strains of taking a trailer over the roads and highways.
Just wondering...
Mark
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Copper and aluminum?!?!!? till Electrical - Systems, Generators, Batteries & Solar 4 02-11-2004 07:39 AM
Rewire with Copper McMullen 1966 Overlander 4 11-18-2003 03:08 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
