Old 01-18-2003, 09:56 AM   #15
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Plumbing in new AS
Here's a picture I snapped at the AS factory of what the plumbing looks like around the Cold Water Heater. Looks like it's the bypass valve. Note different colors for hot and cold water.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-18-2003, 11:23 AM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Lokks just like my plumbing
I like the idea of using color-coded PEX for hot and cold.
One of my previous SOB trailers used the old gray stuff for all of the piping and it was delivered with the city water inlet tapped into the hot water piping by mistake. It wasn't hard to fix, but it was hard to figure out with all pipes looking the same and mostly hidden under the cabinets.
Pick
Some times it''s a cold water heater, sometimes a tepid water heater and sometimes a hot water hotter heater. I just settle for the term water heater.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 01-18-2003, 12:48 PM   #17
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Go to <www.flair-it.com> and look at the pipe and fittings. I have been able to find these items are most RV shops and even Lowe's and Home Depot.
Dwight is offline   Reply With Quote
Old 01-18-2003, 07:33 PM   #18
1967 22' Safari
clarkston , Georgia
copper vs. pex
I went with copper , be sure to use the thicker grade of pipe available at big box stores.
I used braided stainless sections above the rear bumper to connect four quadrants of pre fabricated pipe--- I then fitted with solder sweats , if I felt comfortable with applying heat in the confined space-,- compression fittings if not. I also ran braided stainless to the water heater and sinks to avoid sweating solder in confined, fire prone areas.
This makes isolation of four zones easy to test and replace if necessary,
1 porstide Hot
2 portside Cold
3 starboard Hot
4 starboard Cold
Be sure the heater is properly ducted for cold weather survival.
I could just about pre fabricate and mail these out. I had fun making them and almost made spares!
Todd McDonald
22' Safari
W.B.C.C.I
ATL-----GA
tod47d is offline   Reply With Quote
Old 07-11-2007, 11:12 AM   #19
Devils Lake , North Dakota
Just to clear up the PEX lifespan issue. Cross linked PEX has a lifespan of over 200 years not 10 to 15 years as often cited.
Northwest Mechanical, Inc. - Heating FAQ
Sundance is offline   Reply With Quote
Old 07-11-2007, 12:03 PM   #20
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I've used whatever is easiest to use for the particular application. To replace a section that is long and easy to reach, copper is the choice. However, the copper pipe spaghetti that used to make up the mess near the water tank (piping to pump, drain valve, and bypass to fill the tank with city water), I redid with Pex.
Lynn
WBCCI 21043
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Copper and aluminum?!?!!? till Electrical - Systems, Generators, Batteries & Solar 4 02-11-2004 07:39 AM
Rewire with Copper McMullen 1966 Overlander 4 11-18-2003 03:08 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
