Old 05-20-2009, 11:34 AM   #1
Larry71's Avatar
Allentown , New Jersey
Send a message via Yahoo to Larry71
Copper Pipe Size
This is probably a stupid question but here goes. I am making a repair to a copper pipe line in our 1971 Airstream. I can't figure out what is the exact size of the pipe that I am repairing. I need to know because I want to insert a piece of pex piping and use shark bite fittings to complete the repair. Before I buy any parts I need to know what size I am looking for. The pipe is located in the rear bath area and runs along the floor under the lip that exists between the bath and the hallway. Any help would be appreciated.
Larry
1971 Safari
2005 Nissan Titan
Larry71 is offline   Reply With Quote
Old 05-20-2009, 12:00 PM   #2
Images: 59
Hate to be the bad news bear, but if you can't figure out the exact size of the tubing, it probably has been frozen and swollen to the point where a shark bite won't fit.
You'll need to cut it back to where it's not freeze damaged and start from there.
Old 05-20-2009, 12:15 PM   #3
Larry71's Avatar
No, it wasn't frozen. There is an old repair that was done and the compression fitting failed. I want to replace this with a shark bite or the like.
1971 Safari
2005 Nissan Titan
Old 05-20-2009, 12:16 PM   #4
Larry71's Avatar
I'm not sure if it inside or outside diamater.
1971 Safari
2005 Nissan Titan
Old 05-20-2009, 12:21 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Main feed is usually 1/2,after a tee or so it goes down to 3/8 these are inside diameter,to get inside size ,measure outside then -1/8".1/2" is the smallest 5/8 o.d.sharkbite fitting I have seen. Dave
easyride is offline   Reply With Quote
Old 05-20-2009, 09:36 PM   #6
Larry71's Avatar
Thanks Easyride.
Larry
1971 Safari
2005 Nissan Titan
How to disconnect copper pipe from WH buffaloman Water Heaters, Filters & Pumps 4 11-21-2008 09:21 PM
Any quick fixes for copper pipe? jask12rs 1970-79 Tradewind 9 08-04-2007 11:54 PM
copper pipe/ac mark silberl Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-18-2006 05:15 PM
Copper pipe help Crazyland Fresh Water Systems 26 03-03-2005 06:04 PM
Need HELP! Access to the copper pipe. Crazyland Plumbing - Systems & Fixtures 6 08-13-2004 03:15 PM
